Nitrous?
Old December 25th, 2007, 06:55 PM   #1
1991 GT
Alan is on a distinguished road
Nitrous?
I'm thinking of running nitrous, which kit should I use wet or dry? I have a 91 GT with 141,000 miles on it but the car has a lot of mods.thanks
A.Y. 1991 GT,Tremec 5-speed, flowmaster with catback,3:73 gears to list a few mods.
Old December 25th, 2007, 08:20 PM   #2
95StangMX's Avatar
95 Mustang GT
could you be more specific than has a lot of mods...and what HP nitrous are you thinking about
Old December 25th, 2007, 08:40 PM   #3
1987 ford mustang gt
well see when shes done
where are you at in Tn?And please be more specific on the mods that you have done to the car.i would run a dry 100 shot though.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old December 25th, 2007, 08:43 PM   #4
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
+1 on the dry system
Old December 25th, 2007, 08:46 PM   #5
e3sean's Avatar
1988 lx
9.68@142
i am still a nitrous V. isnt it bad for the motor to run the dry shot or is that why u get bigget fuel system..
Old December 25th, 2007, 08:50 PM   #6
1991 GT
nitrous
BBk headers and X-pipe,Flowmaster catback,Msd cap and rotor,Msd coil,Msd 8mm wires,C&L coldpipe 73mm,C&L MAF 73mm,March ram air system,K&N filter,Ford underdrive pulleys,3 core radiator,new OEM,EGR,and IAC,3:73 gears,sub frame connectors Tremec 5 speed,B&M Pro Ripper shifter,Zoom stage 2 clutch,upgraded 145 alternator,Real H.I.D headlights, The car has been lowered 2" also. Thanks Alan
Old December 25th, 2007, 08:52 PM   #7
1991 GT
nitrous
I live in Corryton Tn. about 15 miles North of Knoxville.
Old December 25th, 2007, 08:53 PM   #8
no it is not bad you need an upgraded fuel system with anymods and nitrous anyways.A dry stems introduces nitrous into the intake and the injectors introduce the extra fuel need{computer controlled}thats why you dont run a dry system on a carbed car. A wet system introduces both fuel and nitrous into the intake but can sometimes puddle and cause backfiring,with a nozzle systems.I would only run a wet if i was going to spray over a 150 shot and then i would opt for a wet plate system instead of a nozzle system
Old December 25th, 2007, 08:54 PM   #9
i know exactly where you are i live in mascot and go to carter high.Ever been to 411 or knoxville dragway?
Old December 25th, 2007, 08:57 PM   #10
1991 GT
nitrous
Cool,maybe we could meet somewhere,I'd like to see your car
Old December 25th, 2007, 08:59 PM   #11
1991 GT
yea,i go to knoxville dragway more its closer to home only about 12 min. away.
Old December 25th, 2007, 08:59 PM   #12
I dont have it back yet from paint and its completely stripped,rebuilding it from the ground up and building a 347 stroker for it
Old December 25th, 2007, 09:01 PM   #13
ill be there all the time after march when i get my car done,prolly not gonna run it all the time though
Old December 25th, 2007, 09:04 PM   #14
1991 GT
Yea,I'll do that when mine is ready to build,I just bought the car about 5 wks. ago. Back into Hot Rodding again feels good.
Old December 25th, 2007, 09:09 PM   #15
what was the last car you had
Old December 25th, 2007, 09:10 PM   #16
1991 GT
I was thinking of a wet system 75-100 shot no more,what do you guys think?
Old December 25th, 2007, 09:12 PM   #17
1991 GT
I had a 69 Mach 1,and a 68 coupe
Old December 25th, 2007, 09:13 PM   #18
to tell you the truth i would do a dry,unless i was going to shoot ove a 150 shot b/c a wet system can cause puddling of gas in the intake and cause backfires
Old December 25th, 2007, 09:13 PM   #19
nice.
Old December 25th, 2007, 09:15 PM   #20
1991 GT
This is my 1st fox body and I really like it.
Threads Similar to: Nitrous?
Nitrous 05MUSTANG4.0 V6 Mustangs 1 June 28th, 2007 04:10 PM
nitrous. 232stang The Clubhouse 4 May 9th, 2007 01:49 AM
Nitrous blackie New Members Introductions 3 May 7th, 2007 10:03 AM
Nitrous. Texan_Stud V6 Mustangs 33 January 16th, 2007 05:22 PM
