Installing valve cover breather
Old December 26th, 2007, 12:36 AM   #1
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I think im going to order a set of trick flow valve covers and they dont come with any holes for breathers. Just wondering if i just order a push in breather and drill a hole to fit the grommet. Or is their something else I will need??
Old December 26th, 2007, 12:37 AM   #2
1987 ford mustang gt
well see when shes done
just a grommet a breather and a large drill bit
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old December 26th, 2007, 12:39 AM   #3
jam77's Avatar
1987 Mustang GT
Thats what I was kinda thinking but i figured I would ask before I butcher a nice set of valve covers Lol ..
Old December 26th, 2007, 12:42 AM   #4
they even say on there website that that if you buy them you will have to rill a hole for a breather
Old December 26th, 2007, 12:43 AM   #5
jam77's Avatar
1987 Mustang GT
I should have looked before I asked.
Old December 26th, 2007, 12:49 AM   #6
i would of asked before i looked also,so while im looking i can get answers
Old December 26th, 2007, 12:54 AM   #7
TENGRAM is on a distinguished road
if you're gonna run breathers you NEED to disconnect the pcv hookup in the back of the intake manifold. otherwise air will enter the breather and be drawn into your intake via the PCV hose. this is equivelant to a big vacuum leak since this is air that is not being metered by your MAF meter.
2 options:
1) use the stock setup (pcv valve and hose plus the tube from TB to oil filler tube, or
2) use two breathers and no PCV
89 GT t5 3.73
www.my5oh.com/
Old December 26th, 2007, 01:07 AM   #8
jam77's Avatar
1987 Mustang GT
how would you go about plugging the pcv ? On my stock set up they had me pull the line off the tb and plug it and attach a filter to the end of a hose coming off the fill neck ( s/c set-up). Now I need to get a set of valve covers to clear my roller rockers.
Old December 26th, 2007, 01:09 AM   #9
the simple way would be to just cap off the port on the PCV valve. there are better looking ways i'm sure but that'll get the job done.
89 GT t5 3.73
www.my5oh.com/
Old December 26th, 2007, 01:11 AM   #10
e3sean's Avatar
1988 lx
9.68@142
what is the function of a pcv valve exactly??
Old December 26th, 2007, 01:17 AM   #11
crankcase ventilation. keeps the fumes and pressure from building up in your oil pan.
89 GT t5 3.73
www.my5oh.com/
Old December 26th, 2007, 01:18 AM   #12
jam77's Avatar
1987 Mustang GT
do I have to run two breathers if I plug the pcv valve ??
Old December 26th, 2007, 01:24 AM   #13
in theory yes
Old December 26th, 2007, 01:26 AM   #14
e3sean's Avatar
1988 lx
9.68@142
i thought that was what it was for.. cause the blowby from the rings i am guessing...
Old December 26th, 2007, 01:28 AM   #15
yes. while one is venting the other would be allowing air in to displace the crankcase fumes. picture a straw with one end closed. not much air is going to leave the straw unless you open the other end.
89 GT t5 3.73
www.my5oh.com/
Old December 26th, 2007, 01:33 AM   #16
plus if you increase the temperature (to operating temp) there will be a proportional increase in pressure (PV=nRT for you chemistry nerds). this increased pressure will fight (albeit unsuccessfully) against your pistons as they move down the bore unless you can vent the excess pressure. PCV actually helps the engine produce more power. creating a vacuum in the crankcase works even better. reason why drag racers use vacuum pumps and header evac systems.
89 GT t5 3.73
www.my5oh.com/
Old December 26th, 2007, 01:48 AM   #17
e3sean's Avatar
1988 lx
9.68@142
look ma i learned somthin new today...lol
Old December 26th, 2007, 02:10 AM   #18
jam77's Avatar
1987 Mustang GT
what if I get a neck with a fitting for line that comes off the stock valve covers and keep the pcv valve? It would be just like the set-up I have now and it will give me the clearence needed for the rockers. Ive read you can grind the stock covers to get them to clear roller rockers but not sure.
Old December 26th, 2007, 02:18 AM   #19
the way you have it now (with the filter on the end of the hose coming off of the fill tube) is still letting in a small amount of unmetered air, but IMO it is a negligible amount. your idea should work fine.
89 GT t5 3.73
www.my5oh.com/
Old December 26th, 2007, 02:25 AM   #20
jam77's Avatar
1987 Mustang GT
That was the way Paxton said to do it in their manual. Im going to check tommorrow and see if there is any chance getting the factory covers to work that would save 100 bucks.
Threads Similar to: Installing valve cover breather
BBK Valve Cover Gasket Hotrodvdog 99-04 20 December 24th, 2007 05:09 PM
Valve cover options caintcatchmyGT 96-98 21 October 24th, 2007 06:20 PM
Valve cover filter? energiesource 99-04 10 July 27th, 2007 01:59 AM
valve cover gasket terribleonexx88 5.0 Mustangs 5 July 25th, 2007 03:20 PM
89 LX pinging from valve cover Steves LX 5.0 Mustangs 3 January 3rd, 2007 10:57 PM
