Installing Headers
Old September 6th, 2006, 05:23 PM   #1
niggadrew's Avatar
niggadrew is on a distinguished road
Installing Headers
what are some tips that will help me out?
well shit this town aint big enuf for the both of us
Old September 7th, 2006, 11:12 AM   #2
HORSMEN1995 is on a distinguished road
in a 93 GT fox body, u should have a good amount of room to manuever... depengind on if your installing long tubes or shorties... room should be your biggest concern. just make sure u clean your surface on the heads, and dont over torque your header bolts, but with headers u have to periodically re-torque them
Old September 7th, 2006, 02:25 PM   #3
EDGE23 is on a distinguished road
what's easier to install, long tubes or shorties?
EDGE
Old September 7th, 2006, 02:53 PM   #4
mdvaldosta's Avatar
11.47@120.58
Shortie headers are much easier to install, though longtubes are better for horsepower.
Old September 7th, 2006, 07:55 PM   #5
83 5.0's Avatar
83 5.0 is on a distinguished road
Just installed a pair of Mac long tubes on my 83 this past weekend, having the engine out and installing them was probably the easiest way to do it. Found clearance for tightening bolts pretty tight, had to hammer a box end wrench on a few to tighten.
Some of the tubes seemed to be dimpled on one side to fit the wrench, but the other side had the round edge of the tube close to the header bolt.
Only problem was my gas line and clamp on the front member had tobe moved as headers were sitting on them.
Have some interference with the metal support on the steering shaft flex coupling when turning. Will probably need to flatten it a bit.
Man they come close to the starter (about 3/8") will probably need to build a heat shield or get some header wrap, or will this be okay??
Old September 9th, 2006, 03:50 PM   #6
92mustanglx is on a distinguished road
make sure you use "high temp" lock tight on your bolts from your header flange to your H pipe flange
302, EdelBrock Upper and Lower Intake, GT40 Aluminum Heads, E303, Shaved&Balanced Crank w/bearings, BBK Induction, SuperChip, BBK Shortys, BBK Off Road HPipe, Flow Masters, 4:10, 2" Eibach Drop Springs, 17x9 Chrome Cobra R, 245/45ZR17
Threads Similar to: Installing Headers
Installing MAC l/t headers and prochamber smokeysz4 General Tech 0 October 4th, 2007 11:06 PM
help on installing long tube headers matfernan1 99-04 8 June 18th, 2007 11:52 AM
installing headers fastlane_24 94-95 3 June 11th, 2007 01:48 PM
need help....i'm installing my JLT CAI..... MyLittlePony 2005 - 2010 13 March 16th, 2007 10:12 PM
Installing headers! dmachine22 99-04 9 February 19th, 2007 12:48 AM
