1990 mustang gt
eventually
Fuse Box
does anyone know where in the fuse box the fuse is for the fog lights for a 90 5.0?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
here you go
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears '93 LX 4-banger 78k miles |
#3 | |
1995 Mustang GT
N/A
I Think this is the right one for your year. Double check and let me know. |
1990 mustang gt
eventually
it helps.. i just checked the fuse and its good.. i just bought new fog lights b/c when i got the car it didnt have any on there but now theyre not comin on.. any more suggestions?
u have it grounded? do u have it ran on the headlight switch or a actual fog light switch or do u have it ran through the parking lights and also have you double checked the wiring?
there can only be one....
did you check the fuse with a test light while the ignition is on and the fog lights are in the on postion, if the fuse fails to light up the test light then at least youll know you have a wire somewhere not connected or cut. other then that im not sure
and also forgot to mention one reason alot of people remove the fog lights and bracket is to free up weight in the front and also cause the fog lights had alot of problems with the fox bodys
1990 mustang gt
eventually
theres an actual fog light switch but idk if its grounded or not but it looks like i need to follow some wires lol
#9 | |
1990 mustang gt
eventually
when i got it it didnt have the bracket
do like kuskye said run a light test and see if u have anything and i would almost bet you didnt ground it out
1990 mustang gt
eventually
brb then ill go try it out
1990 mustang gt
eventually
its grounded and its still pluged into the switch and everything anymore suggestions?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires Last edited by chickenbot; December 28th, 2007 at 10:15 PM. |
did u do the light test?
did you use a fuse test light on the fog light fuse while its in the fuse box and the ignition and the fog light switch are on, if so what was the results..
Most likely you have a bad switch or relay. But basically, you are going to have to follow the wires to trouble shoot the problem. I'd start by making sure you have power at the switch, make sure the switch is working, then power at the relay (if your car is equipped with a relay), that the relay is working, and then follow the wires to the fog lights.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Threads Similar to: Fuse Box
| Fuse box | Mikes88 | 5.0 Mustangs | 7 | July 10th, 2007 08:13 PM |
| Fuse Box | Mikes88 | Audio/Video | 3 | July 10th, 2007 12:42 PM |
| Fuse box and IAC | MnrlGry01gt | 99-04 | 7 | April 20th, 2007 03:02 PM |
| fuse | Mustang RacR94 | V6 Mustangs | 5 | April 15th, 2007 10:52 PM |
| fuse box help.....anyone? | Bossman | 2005 - 2010 | 5 | February 8th, 2007 04:41 PM |
