02 Mustang GT
Cant wait to find out
![]() iTrader: 1 reviews
fuel tank
is there any special way that you have to put your fuel tank in, do u have to tilt it a certain way or is there some kind of trick, maybe its just me and the fact that im laying on my back in the wet driveway with no light, but i wasnt sure if there was some special technique. thanks for your help
02 Mustang GT "We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals." |
1988 lx
9.68@142
TRIAL AND ERROR..LOL its easier with 2 ppl
i used a floor jack
85 svo. work in progress
1987 Mustang GT
mine went in pretty easy but i did have two people. be careful not to knock the rubber ring into the gas tank or you will be leaking fuel all over the place
x2. use a little grease on the fuel filler pipe so that it doesn't rip the grommet when you slide it in.
#6 | |
Good floow jack with good wheels. Place it under, release pressure, loosen lines, loosen bolts. Oh yeah, and make sure your tank is empty. First time I did it, I found out why racers run with 1/4 tank... After all is ready to come out, lower the jack. It will get hung on the fill tube. Once it doesn't want to drop anymore on the fill side, slide the tank opposite the the fill side. Remove from under the car. Installation is reverse of removal...
#8 | |
Like he said.... what you did to get it out, you do to put it back in. If you can't get it back in, you shouldn't have taken it out in the first place....
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
Unless... maybe someone modified it while you weren't looking...
Thanks but it was not for nothing, all he has to do is read in reverse and he is good..
Damn homemade Vodka..
#13 | |
Threads Similar to: fuel tank
| GT Fuel Tank | 07 STROKER | 2005 - 2010 | 29 | November 13th, 2007 08:37 AM |
| Fuel Tank | javier351lx | 5.0 Mustangs | 2 | October 19th, 2007 02:30 AM |
| Need Fuel Tank Help | mikebert | 5.0 Mustangs | 2 | December 10th, 2006 11:43 AM |
