1993 Mustang LX Vert
Fuel Rails
I just finished building a 306 with DSS -13cc pistons, (8.98:1 CR) TF 58cc heads, TF 1.6 roller rockers Anderson HiRev valve springs and I'm planning on running 24# injectors with a Accufab AFPR, do I need to upgrade the stock fuel rails and fuel pump? I will be installing 70mm throttle body along with a 80mm MAF
the rails are fine to support your engine easily, the pump is alway s a good idea for the future and if it has some miles on it as well
Stock pump, highly recommende. Stock rails should be good for around 500hp... should also do adjustable fuel pressure regulator...
1988 lx
9.68@142
if u have to upgrade to a 351 or a dart block thats when you need to upgrade your rails.
Yeah I plan on running a Accufab AFPR. What size fuel pump do you reccomend, and also inline type or intenal fuel tank type?
1988 lx
9.68@142
in tank.. 255 lph walbro
1987 ford mustang gt
well see when shes done
why is the c/r so low?
1988 lx
9.68@142
its a stock block stroker im sure he is already making some good power if he adds too much boost he gets to kiss that block bye bye
1987 Mustang GT
yeah i would go with a 255 lph in tank pump. That compression ratio would be good for throwing some boost at it other than that it is kinda low
#11 | |
![]() shurb - if I were you,I would replace the in-tank pump with a higher-flow replacement(only because stock units are proven un-reliable in my experiances). Your rails are fine for what you have.
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
#12 | |
in thre morning and i have no clue as to where i came up with a stroker!!Some blocks will last 2 seconds and some wil last 4 years making over 500hp its still a stock block and if i built something that was gonna be making over 500hp i would buy an aftermarket block.And i was not referring directly to boost,just power in general |
The Razor's Edge
hey keep us updated on the DSS....i've heard bad things about them on here
The Razor's Edge
and get rid of the stock fuel pump...you wont be sorry and its cheap
I kept the CR low to add a supercharger, hopefully in the near future, any ideas?
Boost, boost, boost, boost...
Threads Similar to: Fuel Rails
| Fuel Rails | Euroeater95 | 94-95 | 9 | August 31st, 2007 04:10 PM |
| Holley Fuel Rails | Skullman | General Tech | 3 | September 26th, 2006 02:38 PM |
| Help! Fuel Rails | Skullman | General Tech | 0 | September 24th, 2006 09:09 PM |
| Hi-Flow Fuel Rails for 94-95 | Zak | 94-95 | 5 | August 30th, 2006 03:32 AM |
| fuel rails | 03stanger | General Tech | 0 | June 8th, 2006 08:17 PM |
