Discussing Injector help in the 5.0 Mustangs Forum. ok so i bought a set of injectors they are from an 03 cobra and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1988 lx 5.7
11.6@109
Injector help
ok so i bought a set of injectors they are from an 03 cobra and the plug hole is too deep could i shave the injector side down to make it work?? i dont see why not i just wanted to get some input before i started cutting.. they run on the same electrical pulse i am positive i can get to mate it may not clip on but i can make them shay in..
#2 | |
Black Mamba
2003 Cobra
11.14@124.36
I wouldn't..... Its going to cause loose connections and problems down the road. I wonder if all 4Vs use the same socket. You may be able to yank a harness from one out of a junkyard and solder the other connectors into your existing harness.
![]() Black Cobra Club Member
1988 lx 5.7
11.6@109
just to note i just want to shave the plastic to flush the petal prongs with the hole like the oem injectors then it should be able to be plugged in. do u think it could be done?
1988 lx 5.7
11.6@109
maybe ill just sell them and get another set i dont want to cut and splice i dont want to mess with the integrity of the wires..
#5 | |
Black Mamba
2003 Cobra
11.14@124.36
After looking at the pins closer not only are the offset in the hole but they are sunken in. Are the base of those injectors even the same? Its better to sell them.
1988 lx 5.7
11.6@109
yes they are the same leinght they fit in the rail and intake the plug fits in it just doesnt go down all the way. the only differnce are the pins sit a little deeper in the socket and the pins are not as wide.. i just posted an add on craigslist to sell them so hopefully someone wants them..
someone sells injector harness extensions to mate the stock injector harness to those injectors. if i remember who i'll post it up.
91 Sonic Blue Goodness
19.83 @ 12mph
Ford sells the harnesses for around $8.00 a piece.
you have to splice your wiring to get the Cobra injectors to work. I did the same swap from 19 the 39 as you did. Make sure you get yourself a tune for them man. I would also invest in some heat wrap as well. electrical tape= poop when hiding hot wires. |
2005 skittle
low 13's
[quote=HMUSN;745290]Ford sells the harnesses for around $8.00 a piece.
you have to splice your wiring to get the Cobra injectors to work. I did the same swap from 19 the 39 as you did. Make sure you get yourself a tune for them man. I would also invest in some heat wrap as well. electrical tape= poop when hiding hot wires.[/quote] so thats where poop comes from |
MuchCoolerThanGTsetGO
SLOW
Use the adapters like HMUSN said...
They work great... |
1988 lx 5.7
11.6@109
ya but for the cost of these plus 64$ for the connectors i could have bought a set made for my car so ill just sell these and get the right ones so i dont have to worry about it.. what year did they start putting this style on mustangs or is it just cobras??
19.83 @ 12mph
the pigtails for the 39 pound injectors are exclusive to the 03-04 Cobras
#13 | |
2006 Mustang GT
Now you have the right idea. Do not modify the stock harness or these injectors to try and make them work it will only end up casuing problems. Get the Correct Injectors in the correct flow rate you need.
![]() 2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII |
19.83 @ 12mph
I had no problems when I did it
![]() remember you will NEED a tune if you up your injectors man. |
1988 lx 5.7
11.6@109
i know my car is still in peices and it just got switched to mass air from speed density plus there is a 347 stroker going in with a set of 373's and a rebuilt transmission the car is going to be 100% differnt car then when i drove it into the garage.. and its sad but thats all i got to do.. when i bought it the guy drove it to my house and all i did was drive it into the garage from the street and rip the engine out same day. i never even got to feel what she could do before i started everything.. so ya its gonna need a good tune.
19.83 @ 12mph
good luck with her.
Yes, there are adapters that enable you to make these work without modifying ANYTHING.
1988 lx 5.7
11.6@109
19.83 @ 12mph
that'll work
1988 lx 5.7
11.6@109
Threads Similar to: Injector help
| Injector Help | kumay91 | 5.0 Mustangs | 52 | December 18th, 2007 12:52 PM |
| Injector Help!!! | 95kystang | V6 Mustangs | 14 | November 2nd, 2007 01:35 AM |
| injector help | Black Five 0h | 5.0 Mustangs | 6 | July 22nd, 2007 11:18 PM |
| injector question. | Slicey | 99-04 | 3 | April 10th, 2007 03:35 PM |
| Injector Help | angermgt | 5.0 Mustangs | 7 | November 8th, 2006 01:33 AM |
