Discussing Anyone seen these hydro assist systems in the 5.0 Mustangs Forum. Its notbad we built a setup for bio deisel for under $500 ( note biodeiesl and ...
Old December 31st, 2007, 09:54 AM   #21
86ttops's Avatar
86,97 mustang gt t tops
n/a
Its notbad we built a setup for bio deisel for under $500 ( note biodeiesl and veggio oil not the same veggi oil filter and pour in take but if you live where i do il you have to heat it where bi diesel you take out the fatt and add methanol to stablize it and it is as good as deisel if not better I been thinking veggi oil i can run a seprate tank heat it using 110 v water heater elements and insalate the hell out of the tank and lines i have a 2000 watt inverter already
Originally Posted by Darrell View Post
Biodiesel is the way to go if you can find enough vegetable oil donors. The equipment to make it isn't cheap but it pays for itself in no time. I've been doing some research on it and I'm thinking about trying it.
Old December 31st, 2007, 10:00 AM   #22
86ttops's Avatar
n/a
my budy has a 7.3 been running vegg oil for 3 years has a Greasecar Vegetable Fuel Systems on it no problems but iam not spending $2500 on it i like to do things my self anyways
Originally Posted by ujslost View Post
good idea IMO. just get the 6.4 or 7.3, the 6.0 is what we ford techs refer to as the sick.0, its a POS.
We have some guys that have a fleet of PS diesels that they run bio diesel in, and they make it themselves and it cost them $1 a gallon after they filter it. So $33 to fill up a diesel rocks! just know that you will replace the $400 fuel pump about every 12 months or so. but with the savings on fuel its worth it.
Old December 31st, 2007, 07:14 PM   #23
p-351's Avatar
90&94 GTs; 79&91 Broncos
Originally Posted by Stangzilla View Post
The concept of water injection your right has been around for years but you are wrong by saying it is a power adder. It is far from that.
????????????????? Snow Performance: Home Water injection (engines) - Wikipedia, the free encyclopedia?????????????????
Old December 31st, 2007, 07:26 PM   #24
nolife's Avatar
What are you trying to say? If you are saying it is a power adder than I disagree. It lowers combustion intake charge which puts you at less risk for detonation. Lower intake charge by itself might provide a little power but being further from detonation allows you to do other things (more boost, more timing, less retard etc..) which will add more power that you would not be able to add safely without risk of detonation if you did not have the lower injection temperature. So indirectly, it does not increase power but allows you to tune or add to what you have for more power safely.
1991 GT - Original owner, all stock
1988 GT - The project car
Old December 31st, 2007, 07:28 PM   #25
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Water injection is not a power adder. Water injection is simply an intercooling type of device. It allows more compression or boost for a given fuel octane rating. There are 3 power adders. Nitrous Oxide, Supercharger and Turbochargers.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old December 31st, 2007, 07:36 PM   #26
p-351's Avatar
I guess I should have used my words a little more carefully in my first post-I agree that water injection by itself does not make more power, but allows you to add more boost, timing, etc... . Sorry for the confusion
Old December 31st, 2007, 07:38 PM   #27
p-351's Avatar
Don't forget stickers and big wings----ricers love em!!!
Old December 31st, 2007, 07:39 PM   #28
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I don't know about big wings but stickers for sure.
Threads Similar to: Anyone seen these hydro assist systems
Changing from cable to hydro? Phoenixx Drivetrain 2 October 7th, 2007 01:12 PM
oil cooling systems wadepetersen V6 Mustangs 2 August 27th, 2007 11:45 AM
Exhaust Systems Snipe061 V6 Mustangs 3 March 6th, 2007 10:08 AM
Exhaust Systems! FastBack71 Modular Mustangs 5 February 26th, 2007 03:42 AM
exhaust systems villatic V6 Mustangs 20 January 29th, 2007 09:38 PM
