Trying to get my 347 to fire, Help please!
Ok, to make things quick, I put in a 347 shortblock, AFR 185 series heads, Edlebrock Performer RPM manifold, and nasty comp cam that will give me about .580 lift at the valves and the pistons are cut for .600. I used pretty much everything else stock. All my pulleys, mass air, throttle body, egr, etc.
Everything is in the car and ready to go, even fluids... One problem. NO SPARK!!! I cant figure it out. All of my wiring is correct but it just wont throw a spark when I turn it over. I am using the stock ignition/firing system. I have heard a lot of bad things about the 94-95 computers but I would think It would still fire. Any Ideas? any.... please. I am running out of patients with this thing. ![]()
any power to the coil?
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
I have the perfect tool a 3#ford adjuster lol sory man ign is not my stron suiet
ground
1988 lx
9.68@142
if u have power and ground to the coil and no spark the u have a bad coil..
#6 | |
It will run but I would go bigger.. At least 24lb if you dont plan on boost or nitrous..
1988 lx
9.68@142
u might be able to get away with 24lb but i am building my 347 stroker with gt40 topend and i am going to be running 39lb injectors. 19 lb with afr's no way....
thats what I think. It will run but it will be lean as a bitch.. I run 42's with my 347cid with AFR 185's. 36's would be perfect if he is running all motor..
1988 lx
9.68@142
ya i was going to get 36 but i got a good seal on my 39lb injectors..
Well then you had to get them. Leaves room for more...
42 lb/hr injectors on a NA 347??
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1987 ford mustang gt
well see when shes done
MY THOUGHTS EXACTLY IM PUTTIN 30'S ON MINE
I too got a really good deal on them + when all said and done and I get used to this nitrous thing I will be shootin 200+hp and I am already puttin down over 400RWHP on motor.. I would say I have the right injectors..
you do just not everyones 347 makes that kinda power
I know that but you and Ryan were questioning my injector size.. R u jealous because my injectors are bigger than yours?!!!
#17 | |
if the pickup in the dizzy is bad the coil wont spark either. the pickup tells the coil to spark.
1986 Mustang GT t-top time piece! |
#18 | |
#19 | |
Anyway, I think my injector is bigger (see pic).
none of you guys injector set up is as bad as mine......the guy i bought the car from put 36 lb injectors in the car and its almost bone stock right now....not to mention that are crappy injectors that he got used.....the plastic on the squirt end of them is broke on most of them.....im gettin 24 lbers with the vortec im buyin from airforcesvt1 and im gettin his afr 185s to go with it.....im just ready to drive my car with that stuff in it
Threads Similar to: Trying to get my 347 to fire, Help please!
| Fire In A 66 | 460brevill | Classic Mustangs | 10 | December 4th, 2007 12:46 AM |
| irvine is on fire :( | blazor | The Clubhouse | 3 | October 22nd, 2007 03:31 AM |
| We Didn't Start The Fire | oldernewbie | The Clubhouse | 12 | October 6th, 2007 02:39 PM |
| Night of Fire | AtlanticBlue99 | Drag | 6 | September 22nd, 2005 06:33 PM |
