IAC Cleaning
Can i clean the iac valve and if so what is acceptable to clean it with or should i just replace it, trying to fix a idle issue when its warm. And when I cold start it starts then dies the start it again and its fine.
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears '93 LX 4-banger 78k miles |
will this generally fix the iac if it is indeed having an issue.... or should i replace it, obviously id preffer to clean it if cleaning it really works...
thanks
try cleaning it first obviously.. if you still have the idle issue.. replace it
i was just wondering most peoples success rate with cleaning them
on the 99-04's is fairly well.
I don't know about the Foxes though.
ok thanks ill clean then replace if needed
good luck
i cleaned it and ran it with full heat, lights, and rear defrost and idle is more steady then its ever been, now to fix my clutch quadarant tomorrow and this car is done...
thanks for the help
no problem
Threads Similar to: IAC Cleaning
| Cleaning Kit | trueballerisme | 2005 - 2010 | 25 | October 7th, 2007 08:59 PM |
| Cleaning the EGR? | fastford3388 | 5.0 Mustangs | 1 | May 24th, 2007 05:36 AM |
| I need your cleaning help. | TheUNZippee! | 2005 - 2010 | 21 | May 4th, 2007 03:53 PM |
| Cleaning | The eaglenator | General Tech | 3 | October 13th, 2006 03:11 PM |
| IAC Cleaning | 99mustang232 | 5.0 Mustangs | 7 | July 17th, 2006 01:47 PM |
