Discussing Options for my 86 in the 5.0 Mustangs Forum. hey i have an 86 gt. i just pulled the motor and stripped it. i ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1986 mustang gt
Options for my 86- gt-40p heads -shorty headers -24 pound injectors -cobra upper and lower intake manifold -comp cam 512 lift i already have gears and a new t-5 tranny. i was just wondering are all these parts going to be compatable with eachother and if not wat modifications am i gonna have to make, such as push rods, valve springs, rockers n such to adjust to my cam. any info would help a shitload. i wanna get this back together and see wat kinda power im gonna make. |
2005 skittle
low 13's
scrap the cobra shit and build it right....any stroker kit is stronger than the stock stuff
4 banger club member |
that is a good budget build, very similar to what i have.
is this speed density or mass air? If mass air, you might want to get a bigger meter calibrated to those injectors. you will always want to check PTV, and get an adjustable pushrod to check for the correct pushrod lenth..also a good set of roller rockers 1.6 or 1.7 will be better than the stock rockers. go ahead and get a good set of springs too. comp cams has some pretty cheap...FMS also makes some specially for GT40/GT40P heads.
393 dropping in a foxbody near you, very very soonMilitary Crew E-3 Combat Engineer |
1986 mustang gt
yea i have a mass air conversion for it to
86,97 mustang gt t tops
n/a
Are you changing pistions? they are flat top in 86 to build more comression dont no a hole lot about building motors but do no you cant add a cam to a stock 86 motor i would think that cam would drive holes in your pistions
sounds like a good start is to get a good bottom end/stroker kit for it
1986 mustang gt
aright so now ive decided in the stroker kit. now the question is which kit would be the best for the 512 cam i have
#8 | |
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
Get rid of that cam too. Go bigger with that also.. Might as well. Its not what stroker kit goes with your cam its what cam goes with your stroker kit...
#10 | |
i am almost exactly where u are my 347 kit is getting put in the engine now i have gt40P heads ported/polished on a flow bench gt40(explorer) intake 347stroker kit fordged rods/fordged flattop pistons 39lb injectors mass air conversion freshly rebuilt t-5 still deciding on 373 or 355 gears awaiting subframe connectors still deciding on electric or flex fan high volume oil pump 255 lph walbro fuel pump |
Go electric.... for sure..
n/a
I know but he didnt say he was changing the bottom for sure just pointing out the facts about the flat top pistion so back at ya
![]() And what does mass air have to do with it? |
2005 skittle
low 13's
yes cam should be one of the last things....go 347......
n/a
piss on it go 351w thats what iam going to do and maybe stroke that out after i get it back together
#16 | |
Dont you want to stroke it before its together. I always have better success that way..
if its out he may as well stroke it...wait what are we talking about?? well ither way stroke it
Yeah Stroke It!! Wait R We Talkin About Engines Anymore?!!!
hell man either way stroke the engine and your "rod" when your done with the engine.
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801 |
Threads Similar to: Options for my 86
| To many Options..LOL | Kosinski | 96-98 | 3 | September 21st, 2007 12:20 PM |
| New options for my '05 | NeoAnderson48 | V6 Mustangs | 9 | September 9th, 2007 11:14 PM |
| So Many Options...... | 98SilverBullet | 96-98 | 13 | May 14th, 2007 11:12 PM |
| What Would Be The Better Out Of These Two Options? | Bossman | 2005+ | 4 | October 6th, 2006 09:23 AM |
| CAI options | grizzly03 | V6 Mustangs | 23 | September 12th, 2006 11:41 PM |
