Simple 351 questions
Trying to figure out what type of water pump (mechanical or electric) and oil pump to use with my 408 stroker. Its going to be a carbed 450-500hp street/strip setup....with more street than strip lol
Stock replacement Melling, TRW or Sealed Power oil pump. If you can afford it get an electric water pump. They free up a few horsepower and cool better and more consistent.
1988 lx
9.68@142
how reliable are electrical waterpumps?? i thought about getting one but my car will be driven a lil more than on a track?
1988 lx
9.68@142
not trying to jack your thred just courious and darrell knows most..lol
I've run them on the street for years and never had a failure yet.
thanks for the tip now i just need to figure out if i wanna save for the electric or not
at wat point would you switch to a performance oil pump or should i say will the stock pump not be enough
I can't answer that question. My last motor made just over 700 horsepower and I was running a stock replacement pump. Alot of the big engine builders use stock volume pumps. From what I've been told by engine builders is you run a big oil pan with a standard volume pump and 5-6 quarts of oil to keep the oil away from the crank. The high volume pumps draw more horsepower to operate, put stress on the distributor and requires more oil otherwise it will drain the oilpan. I've been following this advice for years and its been working for me.
thank you so much lol saved me some cash ha ha and probably headaches
Threads Similar to: Simple 351 questions
| simple yes /no | JASonic | V6 Mustangs | 6 | September 14th, 2007 06:08 PM |
| Simple CAI question | Hourofpain | V6 Mustangs | 21 | August 4th, 2007 10:35 PM |
| A Simple Question: | WAR-PARTY | The Clubhouse | 16 | June 30th, 2007 02:48 PM |
| There has to be a simple fix for this... | 1FastFox | The Clubhouse | 5 | June 18th, 2007 07:10 PM |
| A few simple exhaust questions. | myroush6 | 2005 - 2010 | 9 | April 28th, 2007 02:48 PM |
