1993 Mustang LX Vert
Cleaning engine bay
Does anyone have any suggestions on this process? The engine and trans are out. The part I'm concerned about are all the unconnected plugs and the electrical harnesses. What products were used would be helpful. Any suggestions and advise would be greatly appreceated.
steam.
1987 ford mustang gt
well see when shes done
1988 lx
9.68@142
if everything is out just go wild on it use the engine degreeser and a pressure washer.... then let it dry out before you connect anything. what year is your car?? just cover any fuze boxes and fuel lines..
1988 lx
9.68@142
make sure u get the degreeser that is safe on wires.. i think the gunk engine foam is safe. carb cleaner works great for the tuff greese
gunk is just like kerosene.
i spent almost a moth strippin my engine compartment with a rolock disc,welding all the holes and smoothing it all back out.Then another 3 weeks under the car.
1988 lx
9.68@142
![]() I meant get it steam cleaned. ![]() no use a hand helf steam cleaner
93 LX convertible
1988 lx
9.68@142
ya so i dont think there is anything you could hurt just degreese it and pressure wash it then carb cleaner with a final wipe down.. steam cleaner would work good if u have one..
exactly like e3sean said, just maybe use a sponge to
laquar thinner or aceitone with rubber gloves and terry cloths on big areas and put it in a 409 bottle " the only bottle that thinner won't eat the seals in" spray and brush
The Razor's Edge
i don't know about a pressure washer....thats going to force water in alot of places....use gunk and a brush then i would use a water hose with no sprayer on....
use some purple power or castrol super clean, not diluted , spray it on with a spray bottle or something like that, then used a pressure washer, or pull it to the local carwash and do it there. I have done both a few times and no problems
1986 Mustang GT t-top time piece! |
Brakleen and a well ventilated area, followed by a DA sanding (or by hand with a 3M scotch bright), wash clean, dry, coat with two coats of etching primer, then Krylon rust tough, or if your car is getting repainted, have the body shop paint the engine bay the same color as the car.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
2001 YUGO GT
Carfully tape over all connections and open hoses, it takes about half a day. Use the blue painters tape, so you can see all the stuff is done and it makes it easy to remove. I uesed two cans of Gunk, let it set for 3 hours then hit it with a pressure washer. Let the bay dry out than go back in with a parts brush, and a paste of powered tide and water. hit that with the pressure washer. Now it's ready to finish taping off and painting. If you are worried about any of the plugs having water in them, steal the wifes g/fs hair dryer. A heat gun gets to hot. have fun.
Threads Similar to: Cleaning engine bay
| Engine Cleaning? | Snipe061 | Visual | 14 | September 22nd, 2007 01:04 PM |
| engine cleaning | mustangrebuilder | 2005 - 2010 | 26 | August 18th, 2007 11:49 PM |
| Engine Cleaning | tnknepp | Classic Mustangs | 4 | July 23rd, 2007 07:48 PM |
| Cleaning engine | MustanG_guy17 | 99-04 | 14 | April 20th, 2007 10:22 PM |
| Cleaning Engine | themav46 | V6 Mustangs | 15 | October 9th, 2006 08:23 AM |
