t5 idle
so i did the t5 swap on my car (90lx) and sometimes when i do a 3 point turn or sumthing wen i put the clutch in the rpms jump a lil bit could that be from keepin the automatic computer?
85 svo. work in progress
13.64@101mph
probably...
how much is a little bit? its not from the ECM. did you use the correct harness plus the t5 gear switch? have you pulled codes yet?
maby like 1100 1200 rpm,it usually goes down before it revs up ,i plugged in one connector to the tranny i think it was the back up lights
#5 | |
you should Check for Codes. that'd give us an idea of what is not connected. |
#6 | |
Threads Similar to: t5 idle
| T5 Idle Q? | terribleonexx88 | 5.0 Mustangs | 1 | November 16th, 2007 04:42 PM |
| low idle | roush06 | 2005 - 2010 | 26 | October 24th, 2007 07:13 PM |
| idle...... | sivart | 5.0 Mustangs | 4 | April 26th, 2007 01:09 PM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
| need help my 88 won't idle | smokin' joe | 5.0 Mustangs | 2 | August 25th, 2006 03:59 PM |
