ECM??
How can i tell what ecm is for a manual?
Fastfordsoftexascc.com |
Billy Weston
If its the 93 in your sig it should be a A9L
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
where at on the ecm it say that? I going to look for one in the moring i guy had alot of foxes and strip them and keeped every thing.
what is the catch code on the side? reference that code with the description at this link: Ford Fuel Injection » EEC Program Codes
but, auto and manual ECMs will both work fine a manual tranny (i'd actually prefer an auto ECM) |
#5 | |
click the link i posted. it will explain where to find the code and what vehicle the ECM came in as well as whether it was for an auto or a manual.
i also pointed out, that it makes no difference whether the ECM is for an auto or a manual. it will work fine for a manual. the auto ECMs have a bit more timing advance programmed into them for WOT below 2k rpm. |
that last part is what i didnt understand. but willl it stall on me if i push the clutch pedal in such as stoping at a light.
#8 | |
do you understand the last part now? i don't mind explaining it better if necessary. |
gear switch can you explain to me a lil more on that.
there is a switch on your manual tranny that tells the ECM whether the tranny is in gear or not. if the switch is open the ECM believes the tranny is in gear, closed indicates that the tranny is in neutral. without this switch your ECM will think you are in gear so it will use a different "strategy" and this can mess up your idle.
the gear switch also works with your clutch switch to allow you to start the engine. if either switch is closed you can start the engine. in other words, you can start the engine with the tranny in gear if your clutch pedal is pressed in, or you can start your car in neutral if the clutch is up. ![]()
cool thanks
i think my car threw a code that concerned that switch and thats probly y my car will start without the clutch being pushed in and while its in gear huh
#13 | |
![]() http://i4.photobucket.com/albums/y13...A/DSC00197.jpg his car was in reverse and he backed into the garage with his door open. the door got folded flat against the fender. thankfully he did not get hurt. |
1988 lx
9.68@142
ya thats why when u put in electric start u dont just ground the neutral switch..
