Goin To The Junkyard
Old January 2nd, 2008, 10:09 AM   #1
83five0's Avatar
1983 GT
UNKNOWN
83five0 is on a distinguished road
headin to the pull-a-part. gettin a explorer motor with gt-40's and a C-4 tranny out of somethin out there. seats and manual steering rack. gonna put the stang back together soon.
1983 FOX BODY-LIL SOMTHIN IN PROGRESS
Old January 2nd, 2008, 11:00 AM   #2
13.64@101mph
i think 97 1/2 and up has the gt40p's, what years did the gt40's come off of, my old gt40's were of a recked 93 cobra
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old January 2nd, 2008, 12:58 PM   #3
notchabovechevy is on a distinguished road
StangPro.com - Ford's GT-40P Cylinder Head
this will help with the heads rem. the p's are better heads but require lt's or certain shorties
Old January 2nd, 2008, 03:07 PM   #4
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
i read that before very informitave
Old January 2nd, 2008, 04:58 PM   #5
83five0's Avatar
1983 GT
UNKNOWN
i read it earlier in another thread. i got summit long tubes. dont know how much i would half to bend or "dent" them in. so ill just try to find somethin with aluminum gt40's. anybody know what year came with aluminums?
Old January 2nd, 2008, 05:07 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
What year came with aluminum? None that I know of. Someone will correct me if I'm wrong.
Old January 2nd, 2008, 05:26 PM   #7
83five0's Avatar
1983 GT
UNKNOWN
i know somethin had to come with aluminum gt40 heads. crown vic, grand marquis, explorer, somethin. right?
Old January 2nd, 2008, 05:34 PM   #8
e3sean's Avatar
1988 lx
9.68@142
no ususally stock heads are cast iron.
Old January 2nd, 2008, 05:45 PM   #9
nolife's Avatar
91GT, 88GT, 02GT
Crown Vic and Marquis were 4.6 mod motors since 1991 I believe and cast iron before that and the only GT40 aluminum heads made by Ford are the GT40X, Y and Z and none were on production cars.
The iron GT40P is the best your going to get at a junk yard. From what I've read, the regular iron GT40 is also an improvement over the stock heads but is that "improvement" worth the time and effort of swapping out just to keep your existing exhaust headers? That is your call.
Old January 2nd, 2008, 06:36 PM   #10
1987 ford mustang gt
well see when shes done
nope they were all cast iron
347, torn apart again.
Old January 2nd, 2008, 09:10 PM   #11
The Razor's Edge
White Thunder's Avatar
dont the stockers fit?
founder of the FTN Club
Old January 3rd, 2008, 10:39 AM   #12
13.64@101mph
yeah like no life said...nothing came with aluminum heads stock...the gt40's in mustangs and explorer's are cast iron...so arent the gt40p's...the ones from fms themselves are aluminum
Old January 3rd, 2008, 10:59 AM   #13
83five0's Avatar
1983 GT
UNKNOWN
im getting a whole motor. not just heads. from what ive heard, good luck tryin to find gt40p heads. so ill get whatever i find. as long as its a 5.0 and turns over by hand. gotta get alot of stuff. im gonna try to build an 12-11 second car out of scrap yard parts.
Old January 3rd, 2008, 12:09 PM   #14
baine21225's Avatar
gonna find some nitrous while your there?
Old January 3rd, 2008, 01:47 PM   #15
83five0's Avatar
1983 GT
UNKNOWN
no the cam, nitrous, drag radials, and stall will be new
Old January 3rd, 2008, 05:18 PM   #16
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
can't you port the p heads and make them flow pretty good?
Old January 3rd, 2008, 05:23 PM   #17
JayVee's Avatar
2003 COBRA 10th ANNI.
JayVee is on a distinguished road
Send a message via AIM to JayVee
bump...
FOR A WOUNDED MAN SHALL SAY TO HIS ASSAILANT, "IF I LIVE, I WILL KILL YOU... IF I DIE, YOU ARE FORGIVEN". SUCH IS THE RULE OF HONOR.
Old January 3rd, 2008, 07:05 PM   #18
83five0's Avatar
1983 GT
UNKNOWN
the p heads flow pretty good already from what ive seen. heres the plan. i have a fully gutted 83 hatch. gonna go get a 5.0 wgt-40 heads (p or just the 40's), slap performer rpm intake, qf650 carb, 150 shot, trick flow stage 1 cam, lt's, msd ignition and distributor, c-4 with 3200 stall and forward manual valve body, shift kit, some drag radials and frame connectors and solid motor/trans mounts. no a/c no power steering no smog no nothin. this thing doesnt even have the windsheild wipers or motor still on it. hopin to get in the mid 11's- low 12's on this setup. of course im going to re-seal the motor with new gaskets and a new oil pump, pushrods, lifters etc. think i can make 320 on motor?
Old January 3rd, 2008, 07:08 PM   #19
with a 150 shot? Probably more to the wheels.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old January 3rd, 2008, 07:12 PM   #20
83five0's Avatar
1983 GT
UNKNOWN
yeah but 320 on motor. 470 with spray. wonder what it wil put down to the wheels.
Threads Similar to: Goin To The Junkyard
Goin Hunting B0B The Clubhouse 58 November 19th, 2007 06:19 PM
Fox Junkyard Swapable Parts HMUSN 5.0 Mustangs 7 November 14th, 2007 12:35 AM
Junkyard Youngin V6 Mustangs 3 July 30th, 2007 12:14 PM
Junkyard Search For PI Components 98gt 96-98 11 December 3rd, 2006 06:34 PM
Goin to a track zdrainxx V6 Mustangs 3 October 20th, 2006 05:51 PM
