Discussing HELP! What size injectors in the 5.0 Mustangs Forum. i got a 93 5.0 lx notch and it runs like crap and i ...
Old January 2nd, 2008, 03:55 PM   #1
1993 5.0 notchback
i got a 93 5.0 lx notch and it runs like crap and i can barely get it started!!! i think i have 30lb injectors not so sure!!! i have an edelbrock performer setup with a ford racing b cam my question is wat size injectors? 19lbs or 24lbs?
93 5.0 notch-b303 cam,performer rpm heads,performer upper and lower,70mmthrottle body,shorty headers,h-pipe,flows,cai,1.7rr,built aod
91 5.0 lx hatch-Sold
92 5.0 lx hatch-Sold
Old January 2nd, 2008, 04:01 PM   #2
White Thunder's Avatar
2005 skittle
low 13's
19's are stock.....go with the 24's and get a 255 walbro while your at it.....new fuel filter....i hope you dont think this will automaticly fix your problem
4 banger club member
Originally Posted by 8t6gt View Post
*(before) O(after)
Old January 2nd, 2008, 04:28 PM   #3
Casper98GT's Avatar
i hope you have a MAf to match ? 30's are fine for that setup. If it doesnt start very well, i would start the normal diag.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old January 2nd, 2008, 04:31 PM   #4
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
30lb injectors won't hurt but 19lb injectors are more than enough.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old January 2nd, 2008, 04:32 PM   #5
MuchCoolerThanGTsetGO
ChrisJ's Avatar
SLOW
My Junk
www.myspace.com/cjobe
Old January 2nd, 2008, 05:30 PM   #6
nolife's Avatar
What color are your injectors? 30# are red. Whatever you decide, don't forget you will need a MAF that is sized or calibrated for that specific injector size.
1991 GT - Original owner, all stock
1988 GT - The project car
Old January 2nd, 2008, 05:38 PM   #7
e3sean's Avatar
1988 lx 5.7
11.6@109
+1 if u just slap 30lb injectors on without calibrating it it will run like crap..
Old January 2nd, 2008, 05:40 PM   #8
e3sean's Avatar
1988 lx 5.7
11.6@109
do u have a stock fuel pump
Old January 2nd, 2008, 05:51 PM   #9
ChrisJ's Avatar
SLOW
My Junk
Old January 2nd, 2008, 08:42 PM   #10
sneezingfox's Avatar
Awesome charts!
Old January 3rd, 2008, 04:07 AM   #11
Iwannagofast's Avatar
1990 Mustang GT
9.39@76.09----1/8th mile
no kiddin......according to those ill be just fine with a 255 lph pump and 42 lb injectors
Old January 3rd, 2008, 09:59 AM   #12
nolife's Avatar
Each setup is different but once you get up to 42lb injectors, there is a good chance you will have idle quality issues without some type of custom chip or programming. Some people do not have problems but some people do, I'm sure the cam and intake combination has a lot to do with it as well.
MotorSports Digest has some charts that show the effective injector size for those that use increased fuel pressure or an FMU as well.
Old January 3rd, 2008, 11:02 AM   #13
Speedstang302's Avatar
1989 Mustang LX 5.0
12.86@ 111mph
he's be fine with 19s...better with 24lbs and doesnt need 30lbers...
nice charts chris..
and a 190lph pump will be fine for that set-up...
1989 Mustang LX 5.0
347ci stroker tremec 3550
edelbrock heads, comp cam, vic jr intake, 750cfm 4150 holley
11.736@119.868mph
SOLDSOLDSOLD
LOOKING FOR A NEW 5.0...
must be 90-93 black 5.0 5spd GT...PM with replys!!!
Old January 3rd, 2008, 12:04 PM   #14
1990 Mustang GT
yeah im definately goin to go for a dyno tune once my car is done....i have always not only does it make it more streetable and everything it can give ya 30 to 40 horse power on a high hp motor
Old January 3rd, 2008, 07:26 PM   #15
tehdwarvenn's Avatar
so what size injectors would go for a 350 hp turbo'ed 302? does it matter if the hp is from forced induction or compression?
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Old January 3rd, 2008, 09:42 PM   #16
nolife's Avatar
In general, forced induction will need a larger injector for the same HP.
This site has a generic fuel injector calculator with a basic explanation
Injector Selection Guide
The difference is the "Brake Specific Fuel Consumption" value. I have no idea how much these calculations work out in real life situations.
Old January 3rd, 2008, 09:53 PM   #17
imported_Gt_Jay's Avatar
1993 Mustang LX
N/A
So if i'am reading the chart right you can use a 155lph with 24lbs injectors, right everyone
Fastfordsoftexascc.com
Old January 3rd, 2008, 10:50 PM   #18
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I will respond to that with a question. Why would you install a 155lph pump and not a 255lph pump?
Old January 3rd, 2008, 11:53 PM   #19
1993 Mustang LX
N/A
JW if you could.
Old January 3rd, 2008, 11:55 PM   #20
2005 skittle
low 13's
he is saying that there around the same price you should just go with the 255...be easier for the future
*(before) O(after)
Threads Similar to: HELP! What size injectors
39 # injectors and stock injectors for sale 67/07 For Sale 0 September 20th, 2007 10:27 PM
Injectors and MAF size. And other questions.. One Bad Sixxx V6 Mustangs 16 June 4th, 2007 09:14 PM
what size injectors and maf should I use? fogged306 5.0 Mustangs 27 April 22nd, 2007 11:48 AM
What Size Fuel Injectors? killagt46_t-top 99-04 13 March 30th, 2007 07:28 PM
Injectors MnrlGry01gt 99-04 4 November 28th, 2006 01:44 PM
