Thermostat Housing LEAKS... any tips
Old January 3rd, 2008, 11:15 AM   #1
White 89 is infamous around these parts
I just spent a few hours the other day replacing my waterpump. Since I had to replace the waterpump I thought what the heck I will replace all the hoses and thermostat. I got the car all put back together filled the rad. with coolant and I noticed a leak. I got under the car looked and looked and it was coming from the bottom of the theromstat housing. I was happy that is wasn't coming from the waterpump. So I took the thermostat housing back off. Which was a pain because the lower bolt on the right took 30 minutes to take off. It's hard to get to. I went to local parts store and bought a brand new housing. It came with a gasket.
Here is the question.
Is it housing theromstat then gasket
or
housing gasket then thermostat on top.
Also I used Permitex waterpump and theromostat housing gasket sealer.
Should I use RTV instead this time. Any tips for a better seal.
thanks
1989 mustang GT 5.0
Old January 3rd, 2008, 11:30 AM   #2
mdvaldosta's Avatar
11.47@120.58
Use both gasket and type 2 RTV (the kind that's not gasket maker, it'll stay soft). Shouldn't leak then. Make sure the surfaces are clean of any stuck gasket material.
Old January 3rd, 2008, 11:30 AM   #3
kuskye25's Avatar
kuskye25 is on a distinguished road
Thermostat Install - StangNet - Promoting the Legend of the Ford Mustang
i couldnt remember off hand which way it goes i just put mine in the way it came out, but maybe this link will clear it up for you, for my waterpump ive never used gasket sealer just a gasket.
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears
'93 LX 4-banger 78k miles
Old January 3rd, 2008, 11:35 AM   #4
On the waterpump I used Permatex. It was a silver color. I put a bead on the gasket and then spreaded it out with my fingers.
1989 mustang GT 5.0
Old January 3rd, 2008, 01:42 PM   #5
ryans88gt's Avatar
Use ultrablack RTV and let it set up for an hour before you start the car. You really don't need a gasket at all.
Old January 3rd, 2008, 01:48 PM   #6
GodFather aka Perky's Avatar
1988 Mustang LX coupe
GodFather aka Perky is on a distinguished road
* Place the thermostat on the housing with the spring side going towards the intake.
* Use a little gasket sealer (Permatex Blue is my preference) to help hold it in place while you are moving it.
* Put the gasket on AFTER the thermostat so the gasket will be touching the intake when installed. Use a little gasket seal to hold it all in place and make sure no leaks will occurs.
* Now, replace the thermostat housing and the bolts, tightening them together so as to not cause the thermo to squeeze to one side and you should have a nice snug fit.
* Let the sealer "cure" for recommended time before starting her up.
'88 White 5.0 Coupe - AOD w/shift kit w/stock cam - Typhoon intake, Edelbrock hds (1.90/1.60), Crane 1.7 rollers, 76-mm MAF, 70-mm TB, polished VCs, 4.10 gears. Coming soon...Hi-stall converter, mod VB, XE264HR cam and TMoss ported Explorer intake.
Old January 3rd, 2008, 03:09 PM   #7
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
just like ryan said the black rtv works awesome
Old January 3rd, 2008, 05:31 PM   #8
JBIGBOOTSY's Avatar
1990 LX hatch
I just use RTV and apply it, start the bolts till there is ~1/8" gap wait an hour, then snug it tight.
Old January 4th, 2008, 09:33 AM   #9
drifts14x is on a distinguished road
I used the blue stuff and a new gasket as well...on my 3rd try.
It's really important to let the gasket set up. I tried to crank right after I got it all back together twice and it leaked like a faucet.
1995 Ford Mustang GT Convertible
Black w/ Saddle/Black Interior
BBK CAI, BBK Shorty Headers, BBK O/R X-Pipe
Tokico HP Shocks/Struts, Mach 460 Sound System
1995 Ford Mustang GT (RIP 10/16/2008)
Vibrant Red w/ Black Cloth Interior
Old January 4th, 2008, 10:43 AM   #10
stang94 is on a distinguished road
I had the same problem, I went back in, took out everything, toss the gasket and user the ultrablack RTV, and never saw a leak again, until the car was total
You have to give it some time let it dry before you, start the car. Just get it from autozone, read the instructions and you'll be fine.
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old January 7th, 2008, 10:29 AM   #11
SUCCESS
I used RTV Blue stuff. I went around all the bolts put a little extra. I let the glue set up for over an hour. Then filled the antifreeze up and no leak. I was happy.
1989 mustang GT 5.0
Old January 7th, 2008, 10:52 AM   #12
JBIGBOOTSY's Avatar
1990 LX hatch
Yea!
Old January 7th, 2008, 11:42 AM   #13
e3sean's Avatar
1988 lx
9.68@142
glad to hear you got it..in the future the black high temp it the best you will never worry about it failing
Threads Similar to: Thermostat Housing LEAKS... any tips
Any tricks for finding exhaust leaks?? 96mystic Modular Mustangs 19 October 2nd, 2009 02:07 PM
My Radiator Leaks nba1341 5.0 Mustangs 11 December 12th, 2007 02:12 AM
t5 bell housing terribleonexx88 5.0 Mustangs 3 October 31st, 2007 06:50 PM
Chrome Thermostat housing. jrfan4life 99-04 9 April 17th, 2007 05:37 AM
Fuel Tank Leaks spicetraders General Tech 0 November 30th, 2006 11:06 PM
