Need Help On Computer ID 86 Stang With MAF Convt
Hello, I have a computer question
I have a 86 mustang that has been converted to MAF and I have a dead wire on the distributor plug wire that controllers the timing. I have trace wire back to computer in car and wire is good. so I may have a back computer. car runs but will not control timing I have to set it manual which means it runs good full out but does not want to run at cruise and has a bad idle .. anyway I have 2 computers the one in the car is EEC-IV SFI-MA12A F3zf-12a650-eb D3D1 on it. my other computer I got off of eBay, by the way it will not start the car so I don't know if its dead or just for maybe the real 86 speed density none MAF system ? or other here are its #'s EEC-IV EFI sd20a E8tf-12a650-as2c g 8RB I see that one of them say's SFI and the other has EFI on it. what does that mean ? and does anyone know what the voltage out put on the wire should be at idle so I can use that for testing ? at the plug ? thanks chad
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion |
ok now the dam thing is working ? 6.5 volts running at sput and 12 when not running with keys on ? must have been loose somewere ?
Threads Similar to: Need Help On Computer ID 86 Stang With MAF Convt
| Computer | akatagyourit | 2.3 Mustangs | 3 | July 24th, 2007 11:02 PM |
| What's the best exhaust system for my 02 Mustang GT Convt? | OhhShorty | Modular Mustangs | 8 | June 11th, 2007 10:06 AM |
| Who Would Win, Stock 2000 Mustang Convt Or 2001 Impala? | zdrainxx | V6 Mustangs | 25 | October 9th, 2006 07:25 PM |
| How Long should A 2000 Mustang Convt Last? | zdrainxx | V6 Mustangs | 10 | September 29th, 2006 03:49 PM |
| New 97 Cobra Convt owner | wrapumup | New Members Introductions | 7 | August 12th, 2006 01:22 PM |
