Discussing powerdyne vs. 342 in the 5.0 Mustangs Forum. Originally Posted by Stangzilla Like I said sell your pistons, get lower compression ones, 10-... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 | |
Why is it not good with high compression?
#22 |
1987 ford mustang gt
well see when shes done
detonation
#23 | ||
Secret In The Works
You can have detonation with 8.0:1 and Nitrous. Higher compression doesnt make it more likely to have detonation, a poor tune does.
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly |
#24 |
Well lets get this straight I am no expert either but for the reason stated by Jordan and also you gotta remember with that high of compression besides detonation you will be raising the cylinder pressure even more when the extra o2 is mixed with the extra fuel during nitrous use. Another thing that comes along with that is an excessive amount of heat that is difficult to get rid of.. Bottom line is that running nitrous on that motor should be left to someone that has experience with nitrous. I would hate to see you toast your motor and for the rest of your life you avoid nitrous like the plague because you will think ahh nitrous sucks because it blew my motor when in fact it was you that did it.. Dude for the 3rd time get rid of those pistons if you are building a street car..
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
#25 |
[quote=Goblin;765430]Huh? Im confused, how does using racing gas have anything to do with fuel economy?
I was not saying race gas made fuel economy bad it came out wrong i was saying it was such a long drive and the car used so much gas it would be useless to drive the car to the track with race gas in the tank when its almost 7 dollars a gallon here. heres how the sentence was suppose to read. my uncle runs pump gas in his camaro[383 sbc,13.5.1 c/r] but it is shit to drive b/c you haft to have the timing pulled back so far.The bad thing about race gas is it is very expensive around here and it would be useless driving it on the street with it in the tank.
347 stroker little iron headed street car. Last edited by Iownastang : January 7th, 2008 at 08:10 PM. |
#26 |
Race gas is expensive everywhere!!
#27 |
oh you can say that again,its just dont make sence to drive to the track thats 45mins. away with a tank full of race gas.
#28 |
Oh I get it...I am just tryin to make this guy understand that running that motor on the street makes no sense either.. And that running nitrous on it prob will be worse..
#29 |
I know exactly what you are saying,all it will be good for is to drive to the track and back if it ill make it.Now thats of course if you dont haul it on a trailer.
#30 |
weekend warrior/strip trailor queen
#31 | |
I am not sure if I am the only one here who has ever ran unusually high compression on the street, but after a while it's just not fun anymore.
Overheating issues, vibration rattling bolts loose the list goes on. For daily driving I would not say anything above 10:5:1 Even that is a little much just from my experience. And yes, if a motor is built correctly, high compression and Nitrous work great, it's a combustion enhancer, which high compression engines need and love. Blowers I say no higher than 9:1 to be on the safe side, because high cylinder pressure and boost have effects on flame center distortion. [/rant finished]
#32 | |
#33 |
zilla ive done alot of research and plan to do alot more before i even spray my 357, and when im more knowledged enough i will spray the 342. also have alot of friends around my area that use(d) it.
#34 |
ok well good luck to you then..
#35 | ||
Secret In The Works
[quote=jordan;766061]
If you are overheating, your cooling system isnt up to par. If bolts are coming loose, you didnt tighten them in the beginning. Do you see racers at the track constantly tightening ALL their fasteners and bolts and nuts all over the place? Ummm, no.. and if you do, remind me to stay away from those guys. Lots of engines out there run high compression, and never have overheating problems. What about all the Mopars, Chevys and Fords of the 60s? Most of those engines had 11:1 or higher, and ran fine so long as you used the right gas, and had a good tune. I know this isnt a honda board, but i know of ALOT of honda guys running 12.5:1 and even as high as 13:1 on pump gas, with no overheating issues, or 'rattling' issues that cause fasteners to come loose. 99% of sport bikes today, have over 12:1 compression, and run on pump gas, with no overheating issues. Most exotic cars and super cars, have high compression... with no problems. Even using race gas with a small block ford and high compression, if it overheats.. that means the cooling system isnt doing its job. High compression on the street is very livable and doable, it just depends on what your willing to live with.
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly Last edited by Goblin : January 8th, 2008 at 01:08 PM. |
#36 |
[quote=Goblin;767701][quote=jordan;766061]
Well that makes tons more sense. ![]() sorry for the misunderstanding
#37 | ||
My question to you is....Do you just read a lot of magazines? Or do you actually have first hand experience?
#38 | |
[quote=NottyBoy93;768842]
#39 | ||
[quote=Stangzilla;768913]
I agree totally, and I stated that precise information almost verbatim above ![]() But, having ran high n/a compression on the street, it was a pain in the ass for me, just for me. I know there are guy's like Darrell who just fight through it. But high compression HOT ROD's not crotch rockets are sometimes difficult to tolerate. What Goblin must not see is that a Hyabusa does not require the same cam spec's, air needs and fuel need's that a 12:5:1 408ci motor do. That was basically my point, was that if you have been there, you'd understand.
#40 |
2003 COBRA 10th ANNI.
Keep da motor...IMO...
![]() FOR A WOUNDED MAN SHALL SAY TO HIS ASSAILANT, "IF I LIVE, I WILL KILL YOU... IF I DIE, YOU ARE FORGIVEN". SUCH IS THE RULE OF HONOR. |
Threads Similar to: powerdyne vs. 342
| Powerdyne S/C 96-98 GT Full Kit | nes | For Sale | 19 | January 3rd, 2008 06:01 PM |
| powerdyne superchargers? | B0B | 99-04 | 6 | June 6th, 2007 12:14 PM |
| powerdyne supercharger | 2004GT | Poweradders | 7 | June 4th, 2007 08:18 PM |
| powerdyne | Monster stang 97 | 96-98 | 20 | May 10th, 2007 03:37 PM |
| powerdyne help | timmy40 | Poweradders | 1 | December 21st, 2006 04:32 PM |
