02 Mustang GT
Cant wait to find out
![]() iTrader: 1 reviews
where do i plug in my scanner
where do i plug in the code scanner on my 90 lx...
02 Mustang GT "We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals." |
the connectors can be found behind the driver side strut tower. the following picture shows what they look like,
![]() but they may still have the cover on them which looks like whats in this pic (although this pic is of a 94/95)
The Razor's Edge
all hail tengram
Make sure your scanner is for an OBD1 computer otherwise it wont work. You prob know already but just in case..
The Razor's Edge
02 Mustang GT
thanks yeah my brother has an obdI for his s-10 blazer(gm) but it doesnt work with my mustang.
Is it just for GM? Because the ones I have seen you can change the cartridge for different auto makers.
1987 Mustang GT
The jumper wire method works really well
could you guys explain to me exactly how the jumper wire way works?
im still a little new to fox bodies |
Threads Similar to: where do i plug in my scanner
| Can't Get My Scanner To Pull Codes? | 81 Merc. Capri | 5.0 Mustangs | 10 | December 12th, 2009 05:19 PM |
| will a 4 plug head replace a 8 plug head | CooolCobra | 2.3 Mustangs | 5 | September 19th, 2007 12:12 AM |
| Code scanner / reader | rru95GT | 94-95 | 3 | June 27th, 2007 08:06 PM |
| Scanner | Caio Alves | V6 Mustangs | 3 | November 1st, 2006 10:12 PM |
| Actron code scanner questions | Bill | 5.0 Mustangs | 9 | February 21st, 2006 04:51 PM |
