wheel hop
ok i put my a new rear end in my car with 3.73s in it and i got tubular control arms from blue oval industries, wen i put the rear in i left the quad shock off and now 1st and 2nd have but loads of wheel/axle hop. i thought with aftermarket control arms you dont need the quads. i might just put them back and see if it changes.
85 svo. work in progress
48.47@ 12.58
new shocks/springs as well?
nope. another Q, are gt and lx springs different
48.47@ 12.58
maybe i need better tires
Im not sure if the LX or GT springs are differant as long as they are 5.0 lx springs.
The 4cyl LX springs are softer though. This might be a dumb question but is this a Traction lock rearend?
1986 Mustang GT t-top time piece! |
13.64@101mph
um im pretty sure it has alot to do with the stock rear shocks...what control arms do you have??? cuz not all are going to solve that....
theyre 5.0 springs its 5.0 car. it didnt do it b4 wen i spun the tires only in 1st old gears were 2.73. it has rebuild trac loc. its only wen i stomp it in 1st or 2nd. the control arms are these:
13.64@101mph
This Listing Is Unavailable
![]() ![]() ![]() ![]() ![]() This listing () has been removed or is no longer available. Please make sure you entered the right item number. If the listing was removed by eBay, consider it canceled. Note: Listings that have ended more than 90 days ago will no longer appear on eBay. THANK YOU COME AGAIN
13.64@101mph
im sorry...heard got stuff bout them..but for a set of control arms and sub frames for $179....i'll take my chance's with $500 worth of real parts that i wont have to replace later
1990 LX hatch
I dont know speedy, Rear control arms are pretty hard to break.
of course it wheel hops like crazy, those control arms are ment to suplement the rear suspension system and help to eliminate wheel hop. by taking those quads off its like taking 1 step forward and 2 steps back. aftermarket control arms cannot eliminate wheelhop 100% while taking away "structural integrity" of the rear end (quad shocks) id be willing to bet if you put the quads back on you would notice a world of improvment. imo
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
The Razor's Edge
try putting the quad shocks back on......
The quad shocks are a band-aid for a poorly designed factory control arm and nothing more. They do not add any structural integrity or anything else. Are the rear shocks bad? If one or both of the rear shocks have lost their dampening ability you are sure to experience wheel hop. That is what I'd be looking at. Fancy adjustable shocks aren't necessary, all you need is a shock that works.
#17 | |
13.64@101mph
13.64@101mph
didnt someone on here a couple months ago come on cuz they snapped some cheap control arms with 190rwhp?
1990 LX hatch
He must have had sloppyjosey's girlfriend in the trunk.
Shocks go bad often. Some cheap Vatozone $14.99 shocks will work fine. I'd be willing to bet if he took his shocks off, one or both of them will compress easily and quite possibly not have any tension at all.
Threads Similar to: wheel hop
| 4 In Wheel | Iownastang | 5.0 Mustangs | 15 | December 3rd, 2007 10:11 AM |
| i need a set of wheel for a sn 95 5 lug car in ga | kngkahious | 5.0 Mustangs | 2 | June 30th, 2007 04:29 PM |
| Wheel Hop?? | rjjones43 | 2005 - 2010 | 3 | December 21st, 2006 02:28 PM |
| 99-04 wheel hop | the gillz | V6 Mustangs | 6 | December 20th, 2006 10:12 PM |
| Need Wheel Help | WAVEBYE | 99-04 | 23 | October 9th, 2006 02:59 PM |
