My idle is at 2000 rpm
Old September 11th, 2006, 03:07 AM   #1
slingblade05 is on a distinguished road
my rpm idles at 2000, and sometimes changes after its warmed up... someone said it could be my idle positioning sensor, any suggestions?
Old September 11th, 2006, 09:08 AM   #2
KJeezy is on a distinguished road
Friend's 88 GT idles at 15 to 1600. We changed the IPS and something else, but it still does it. May not be your problem. How's it change after warmup?
Old September 11th, 2006, 10:50 AM   #3
well after it warms up it goes down to 1500 but it varies and will go back up to 2000 sometimes even 2500
Old September 11th, 2006, 03:36 PM   #4
dcraig8 is on a distinguished road
take some throttle body cleaner and with the car idling, spray it around the base of the intake manifold, the throttle body, your vacuum lines and see if anything is leaking by listening for your idle to change while you're spraying.
Old September 11th, 2006, 07:58 PM   #5
1990GT is on a distinguished road
i was just dealing with the same thing, i replaced my IAC (idle air control valve) and it was fixed.i had tried just cleaning it, but it didnt make a difference.
Old September 12th, 2006, 08:38 PM   #6
EDGE23 is on a distinguished road
where is the Idle positioning sensor located, on a 93 lx?
Old September 13th, 2006, 03:04 PM   #7
should be on top of the throttle body.2 screws....3 wires.
Threads Similar to: My idle is at 2000 rpm
2000 GT idle StangAddiction Videos 8 October 19th, 2007 01:04 PM
idle...... sivart 5.0 Mustangs 4 April 26th, 2007 01:09 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
???? about my idle mustangdrvr2019 V6 Mustangs 12 August 7th, 2006 06:05 PM
