Discussing Catch Can / 347 in the 5.0 Mustangs Forum. Is anyone running a catch can on their stroker? Is it needed and is it ...
Old January 8th, 2008, 05:59 PM   #1
1BadFox's Avatar
1988 Mustang LX SSP
Catch Can / 347
Is anyone running a catch can on their stroker? Is it needed and is it really recommended in anyones opinion...??? Pics if applicable...Thanks Fellas...
MUSTANG CLASSIFIEDS: 1988 Mustang LX SSP
http://mustangclassifieds.com/mustang-2587.html
Also posted here on MODDED MUSTANGS/Classifieds
Old January 8th, 2008, 06:26 PM   #2
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I'm assuming you no longer have the factory overflow? If not just buy a cheap Summit catch can.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old January 8th, 2008, 06:45 PM   #3
1BadFox's Avatar
1988 Mustang LX SSP
^ that is true...No oem over flow... I was thinking of the MOROSO can for crank case pressure/catch can...
Old January 8th, 2008, 07:14 PM   #4
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
If you are able to put any oil in a catch can for the crank case you have some issues that need addressing. A PCV valve and breather is all you need. Or a vacuum pump and no breather or two breathers and no PCV works too.
Old January 8th, 2008, 07:16 PM   #5
5pntslw's Avatar
1995 Mustang GT
n/a until march
i have a 347 and all i run is a pcv valve...
'95 GT 347 stroker, auto trans and some gas
Old January 8th, 2008, 07:50 PM   #6
1BadFox's Avatar
1988 Mustang LX SSP
^ yeah me too! I have oil breather and the pcv valve...I have no oil or blow by issues...Just inq. I was just wondering if anyone was running a additional catch can do to me knowing the 347 strokers burn a lil more oil than OEM and just a thought if anyone was running one...Cool!
Old January 8th, 2008, 11:40 PM   #7
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
No actually they don't "burn a lil more oil than OEM" unless there was a machining error somewhere.
Old January 8th, 2008, 11:44 PM   #8
5pntslw's Avatar
1995 Mustang GT
n/a until march
well actually it depends on which 347 pistons and rods you have..... when i had the 5.4" rods mine smoked and burned more oil then i was comfortable with so a friend told me about the 5.315" rods... i got those and no more smoke and very little oil consumption..
Old January 8th, 2008, 11:59 PM   #9
ryans88gt's Avatar
Having a breather and a PCV isn't a good idea, that is basically like having a constant vacuum leak as the PCV is sucking air from the crankcase which is getting air through the breather.
One or the other, or a vacuum pump.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old January 9th, 2008, 12:23 AM   #10
Stangzilla's Avatar
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.”
Old January 9th, 2008, 12:38 AM   #11
ryans88gt's Avatar
that was a worthless post, you just trying to add to your post numbers
88 GT 11.4 @ 118
Old January 9th, 2008, 12:38 AM   #12
Iwannagofast's Avatar
1990 Mustang GT
9.39@76.09----1/8th mile
Originally Posted by Stangzilla View Post
good answer
Old January 9th, 2008, 07:51 AM   #13
1987 ford mustang gt
well see when shes done
i would not of said that,it has nothing to do with the rod to stroke ratio,there are worse out there.A 347 burning excessive oil is a rumor that people started a long time ago.Unless like darrell said ''machining errors.
347 stroker little street car yea its slow!!
Old January 9th, 2008, 10:09 AM   #14
1993 Mustang GT
Here's a question for you guys - Instead of putting a breather on my valve cover to releive crankcase pressure, would one of these work??
Breather tank
Bart
93 Black on Black GT
Kenne Bell S/C
Old January 9th, 2008, 10:57 AM   #15
95StangMX's Avatar
95 Mustang GT
?? waiting on the stroker
ok I am new to the stroker and could someone please explain what i need to do a crankcase breather or pcv or what?
Old January 9th, 2008, 11:11 AM   #16
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Rods have nothing to do with oil burning. Besides that you can't change rod lengths without changing pistons. If you had a 347 that smoked and burned oil then you need to find a different machinist/assembler. I've built several 347s and all of them are still on the road with several thousand miles and none of them burn oil.
Old January 9th, 2008, 11:40 AM   #17
95StangMX's Avatar
95 Mustang GT
understood you explained that myth to me a while back when I started putting together this build....but I do not know or have any info on this catch can or breather, and thought I already had a pcv valve maybe Im wrong but could you explain what these items are for and if I need to use 1 or all of them on my build please professor? lol
Old January 9th, 2008, 11:48 AM   #18
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I'd just use the stock PCV system.
Old January 9th, 2008, 01:34 PM   #19
ryans88gt's Avatar
The PCV valve on an EFI mustang is on the back of the lower intake, it is bascially a check valve with an oil screen under it. A vacuum hose hooks directly from the upper manifold to the valve, you can't really see it unless you look behind the intake.
88 GT 11.4 @ 118
Old January 9th, 2008, 02:28 PM   #20
nolife's Avatar
IMHO, use what was on there before, that is a PCV hooked up and an oil cap with the oil cap vent hole attached to the line near the throttle body. If you are not using forced induction, this should work fine.
1991 GT - Original owner, all stock
1988 GT - The project car
Threads Similar to: Catch Can / 347
MSO didnt think anyone would catch it eh 8t6gt The Clubhouse 24 September 29th, 2007 11:23 PM
Auto vs manual How many mods to catch up? Smoothgrandmama 99-04 19 July 24th, 2007 12:43 PM
cant catch me im the mustang man 232stang The Clubhouse 63 March 27th, 2007 01:02 AM
LUVD QUIT DOUBLE POSTING TO CATCH UP! DSEZ The Clubhouse 23 January 31st, 2007 07:44 PM
