hesitation
Old January 8th, 2008, 08:39 PM   #1
gotime89 is on a distinguished road
hesitation
I have an 89 lx with heads,cam,exhaust,intake manifold but i havent been able to get it running right at around 1500to2500 rpms in fifth gear only do i have a problem it hesitates and backfires when i keep it in that range but if i accelerate it clears up and runs fine. so far i did the timing,plugs,wires,cap.rotor,o2sens,tps,iac,vac leaks, and nothing helps could i need a tune? also dont have cats if that matters.
Old January 9th, 2008, 12:27 AM   #2
ujslost's Avatar
sounds like a vac leak ( i know ya said you checked that already but still) or maybe a MAF or BAP sensor.
Old January 9th, 2008, 12:34 AM   #3
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
i would have guessed vacuum first also.....and if i was the computer goin out you would think it would have trouble at WOT also.....maybe MAF like ujslost said
Old January 9th, 2008, 12:37 AM   #4
ujslost's Avatar
try unplugging the MAF and see if it changes idle or makes any noticable differance. If so then the MAF is probably ok.
Threads Similar to: hesitation
Hesitation gotime89 5.0 Mustangs 11 October 12th, 2007 10:24 PM
hesitation? CBSTANG 99-04 5 July 26th, 2007 08:57 PM
hesitation usmcsawgunner 5.0 Mustangs 9 July 10th, 2007 09:58 PM
Hesitation? 97gtstang 96-98 2 April 16th, 2007 04:56 PM
Please Help! (Hesitation) das50cal 2005 - 2010 4 September 10th, 2006 10:44 PM
