Car has no power
Old January 8th, 2008, 09:09 PM   #1
the88-5.0's Avatar
1994 Ford Mustang Gt
the88-5.0 is on a distinguished road
Car has no power
My car wont idle if the computer advance on the distributer is pluged in has bad power surging an almost all rpm and gets worse as the rpm get higher, i would like to think it the o2 sensors does any one know how to test them? what else should i check?
Old January 8th, 2008, 09:35 PM   #2
kuskye25's Avatar
kuskye25 is on a distinguished road
i wouldnt think a o2 sensor would cause that much mayhem, but dont quote me. when did it start doing this, out of nowhere or what...
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears
'93 LX 4-banger 78k miles
Old January 8th, 2008, 09:41 PM   #3
the88-5.0's Avatar
for a while now it would do it for a few seconds, yesterday got out of school and started it up and and it was doing it, i checked the timing and it off so i got it correct and now it wont idle with the comp. conected to the distrubuter thot it was ign. cont. mod. replaced it and nothing
Old January 8th, 2008, 09:52 PM   #4
kuskye25's Avatar
ok what was its timing then and what did you set to now, so would you say then your adjustment made it worse
Old January 8th, 2008, 09:58 PM   #5
the88-5.0's Avatar
the timimg was at 18 degrees adv i set it back to 10 adv and it would not even idle for a few sec so i put it at 18 adv so it would run, i took to my shop(which is 3 blocks away) and had them thow it on the scanner got 4 codes 12,41,91,18. 91 is the o2 not switching, 41 is the ego i have no clue what the is, 12 is cant control rpm during high rpm check and 18 is no tach input
Old January 8th, 2008, 10:48 PM   #6
Trans Am WS6
ThreeHonks302 is on a distinguished road
Send a message via AIM to ThreeHonks302
I cant really help you on this one, but it wouldnt hurt to at least clean the 02 sensors. Do it with a propane torch... it made my car run better, hopefully its just a simple fix like that, Good Luck!!
Threads Similar to: Car has no power
No power? Beteljuze 5.0 Mustangs 21 May 30th, 2007 08:42 AM
Max Power of an N/A 2V 4.6l? MasterOfEvil 99-04 62 April 29th, 2007 02:30 PM
more power burin_rubber V6 Mustangs 14 February 22nd, 2007 08:01 PM
More Power mjkids Modular Mustangs 11 October 29th, 2006 09:12 PM
What Can I Do To Add Power Without A S/C, I Have 3K via sin dios V6 Mustangs 19 October 28th, 2006 05:53 PM
