Discussing the right set up in the 5.0 Mustangs Forum. I am looking to put on new heads intake and cam in my 91 gt....
Old January 9th, 2008, 11:37 AM   #1
Look Ma! My First Post!
the right set up
I am looking to put on new heads intake and cam in my 91 gt.The set up i was thinking was arp 165 f 303 and a holley systemax intake any one know of a better set up i only got about 2500 to spend
Old January 9th, 2008, 11:39 AM   #2
1993 Mustang GT
Buy the complete Trick Flow setup. Fits your price range, and is engineered to work together. It's a proven combination used by many of us.
Bart
93 Black on Black GT
Kenne Bell S/C
Old January 9th, 2008, 04:30 PM   #3
Speedstang302's Avatar
1989 Mustang LX 5.0
12.86@ 111mph
^^^ that set up wont make 275hp...that intake is designed for more pwr and higher rpm operating range...that cam is NBD...get a trick flow stage 1 cam, twisted wedge heads and gt40 intake...for the street, if doing something else let me know....
1989 Mustang LX 5.0
347ci stroker tremec 3550
edelbrock heads, comp cam, vic jr intake, 750cfm 4150 holley
11.736@119.868mph
SOLDSOLDSOLD
LOOKING FOR A NEW 5.0...
must be 90-93 black 5.0 5spd GT...PM with replys!!!
Old January 9th, 2008, 10:08 PM   #4
1BADSTANG's Avatar
junk the abc cams go With afr heads trick flow intake manifold and custom cam you will fly
331s burn oil and have a bad piston to head ratio.
http://www.StreetChallenge3D.com/sig...?referal=1BAD1
LOL @ THIS http://www.ihateyoujulia.com/?id=0a8...27aa2c6245e4c2
Old January 9th, 2008, 10:18 PM   #5
1987 ford mustang gt
well see when shes done
its not that easy
347 stroker little iron headed street car.
Old January 9th, 2008, 10:25 PM   #6
White Thunder's Avatar
2005 skittle
low 13's
i think this thread would piss darrell off...lol.....i say go with the trick flow set up.....
4 banger club member
Originally Posted by 8t6gt View Post
*(before) O(after)
Old January 9th, 2008, 10:27 PM   #7
ryans88gt's Avatar
+1 get parts designed to work together, plus having a complete kit is always nice.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old January 9th, 2008, 10:49 PM   #8
jam77's Avatar
1987 Mustang GT
i agree go with the trick flow setup
Old January 10th, 2008, 01:16 AM   #9
Stangzilla's Avatar
I am an AFR man myself..
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.”
Old January 10th, 2008, 03:03 PM   #10
1989 Mustang LX 5.0
12.86@ 111mph
yeah for $2500 trick flow top end kit is going to make most pwr...
1989 Mustang LX 5.0
11.736@119.868mph
SOLDSOLDSOLD
