Aluminum block plate
Well hell! I put my flywheel, trans and all back on last night. Forgot to put the block plate on behind the flywheel. I have seen ppl run without them before and just put a small washer on their starter bolts between the starter and the bellhousing. Just wondering what ya guys think.
1986 Mustang GT t-top time piece! |
1990 LX hatch
If you do any substantial amount of street driving, you'll wanna put it back on.
13.64@101mph
+1
Road debris and flywheel/clutch do not mix well.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
13.64@101mph
yeah you really are asking for it by leaving that plate off
I'd take it apart and put the block plate back in.
Im gonna use washers for right now. And if everything is ok with the trans and the vibration is gone, then I will take it back down.
The plate is really just a spacer for the starter and a debris shield.
13.64@101mph
yeah just a debris shield....tell me how thats works for ya...maybe i wont try it
It also serves as a spacer to space the input shaft from the back of the crank.
lol, maybe you can just loosen all the bolts and put washers behind them all.
Do it right or pay the price
+ I think its a rule at the track that the flywheel cant be exposed.. I think..
I guess I should have never started this thread. I know for a fact its not gonna mess anything up. I have seen it done before with no problems at all. Do i wish I had it on , yeah. I also said I was gonna put it back, once I make sure this trans is good.
#13 | |
Not all machined parts are machined the same or have the same tolerances. Maybe one time you seen this done and didn't see any problems occur but how do you know you are not going to have issues now? The plate is there for a reason and not just for a starter shim. What happnes if your input shaft bottoms out the back of the crank? I've seen problems due to not running a block plate in both automatic and manual transmissions. But its your car, do what you want.
#14 | |
1988 lx
9.68@142
ya man if your gonna put it back on later u might as well spend the hour and do it now...if it does what darrell says and messes up the input shaft "and it very well could there is a very fine area between the input shaft and the crank" then you will be replacing the input shaft which is not fun to do cause you will most likely have to open up the tranny cause when u take the shaft off 9x out of ten the 15 needle bearings fall into the case..and that's another thing....check the tip of the input shaft make sure there is no damage on it that is a common problem and that could be causing your vibration.. these guys don't suggest things like that to make fun of you they do it to help save you time and money.your here for a reason and that is to ask questions like that and if u were sure it wouldn't mess anything up u wouldn't have asked it.. it is your car do with it what u will and i hope it works for ya we are just trying to be safe and to tell you what could potentially happen.. |
#15 | |
1987 ford mustang gt
well see when shes done
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
the vibration wasnt the input shaft, you must have missed that thread. I just picked this transmission up and rebuilt it so I know all about the 15 bearings. Took the mic to, and did some measuring with another engine and transmission that I have and there is no way the input shaft is gonna touch the back of the crankshaft.
Then how is the transmission of your car now? how is the disadvantage of block plate on behind the flywheel is not their??
_________________ blanchard grinding |
1982 GT t-top
no proof of purchase
I don't have the plate on my because when I bought it there wasn't one there. I don't drive my car daily or in rain or anything but mines doing ok so far
wow i actually remember this thread
i wonder how this guys car is doing now?
Threads Similar to: Aluminum block plate
| block plate | terribleonexx88 | 5.0 Mustangs | 9 | October 30th, 2007 02:23 PM |
| 4.6 aluminum block | energiesource | 99-04 | 6 | August 3rd, 2007 10:25 PM |
| Overboring a 4.6 Aluminum block | Devilman | Modular Mustangs | 1 | July 23rd, 2007 01:06 PM |
| aluminum block | acg | 96-98 | 1 | February 21st, 2007 09:38 PM |
