Throttle position sensor
Old January 10th, 2008, 11:00 PM   #1
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
I went to put my old sensor off of my 55mm throttle body onto a new 70mm BBK/Edelbrock throttle body and the holding point on the inside of the TPS are not catching the 'flat stem,' the rod that actually moves the butterfly on the new throttle body. It seems that the old TB's flatened part of the rod is slightly wider than the new one, what do I need to do, get a new TPS? Are they all made the same size?
Old January 10th, 2008, 11:37 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Can you post a picture? It should be identical to the factory throttle body. If not you might have a defective piece. What do the instructions say?
Old January 11th, 2008, 12:21 AM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
get an 5.0 explorer tps, they seat deeper, and are longer than the fox tps.
Old January 11th, 2008, 08:27 AM   #4
shurb125's Avatar
The witdths of the flattened part of the butterfly rod are slightly different and I believe that's where the problem lies the difference will not allow the TB rod to catch the fingers that are on the inside of the TPS. I don't have any instructions I bought the TB off ebay. I'll try and get a picture today if possible.
Old January 11th, 2008, 07:20 PM   #5
shurb125's Avatar
Does anyone have any insightful info???
Old January 11th, 2008, 11:14 PM   #6
tehdwarvenn's Avatar
tehdwarvenn is on a distinguished road
Send a message via AIM to tehdwarvenn
off of ebay. was it from a person or from a company?.. cause if it was a person, hes probably selling it for the same problem you had =)
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Old January 12th, 2008, 10:36 AM   #7
shurb125's Avatar
You can tell that it was used and it dosen't seem abused. And it was from an individual.
Threads Similar to: Throttle position sensor
Camshaft Position Sensor jagstang96 96-98 2 November 16th, 2007 12:05 PM
'00 Crankshaft Position Sensor mbooz02 99-04 5 November 8th, 2007 05:24 PM
1999 4.6 cobra camshaft position sensor lovedr79 Modular Mustangs 8 January 2nd, 2007 10:10 AM
Throttle Position Sensor And Power Adders stangempire82 99-04 1 November 19th, 2006 08:14 PM
P0340 camshaft position sensor yellowfever 99-04 1 October 9th, 2006 11:19 AM
