1990 Emissions Question
Old January 10th, 2008, 10:14 PM   #1
motorhead6776's Avatar
2003 Mustang
15.00@93.06
motorhead6776 is on a distinguished road
Send a message via AIM to motorhead6776
Im thinking about buying a 1990 - 1993 mustang lx as a street project but im unsure of what the emissions laws were for that year. anyone know anything about this? would longtube headers be street legal?
Old January 10th, 2008, 10:22 PM   #2
1987 ford mustang gt
well see when shes done
yes they are.If you have emissions then dont get rid of the cats,smog pump,and you have to be picky with cam choice.What state are you in?
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old January 10th, 2008, 10:35 PM   #3
2003 Mustang
15.00@93.06
im in nh
Old January 10th, 2008, 11:22 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
Emissions varries state to state, and county to county.
Old January 11th, 2008, 12:27 AM   #5
nolife's Avatar
91GT, 88GT, 02GT
As for the cats, there is a gap between what the law is, and how and when your vehicle is checked.
As I read it, it is against federal law to remove a catalytic converter on a street car and carries a $2500 fine. This law exists and is in effect regardless if your local area actually checks for emissions equipment or not. Actually removing just about any factory installed pollution control device (EGR, air pump, sensors etc..) falls under the same law. Do people get fines for this? No idea and I've never seen the emissions police driving around
I'm the messenger here and just pointing out the law. Unless your state does periodic checks, no one would know.
Old January 11th, 2008, 12:50 AM   #6
nolife's Avatar
91GT, 88GT, 02GT
Another addition...
The EPA and CARB also have a note that the cats must be original OEM and must not be in a different physical location from "stock" meaning long tubes would move them and you are not supposed to substitute the four cats that are stock in a 87-93 Mustang with two high flow cats that are common in the aftermarket. Enforcement of these laws appears to be non existent and there are loop-holes.
Any one here with their inspection or emissions license? Do you have some type of reference to know where exactly every car is supposed to have their cats at while doing your visual inspection? This is insane.
Again, if your area no longer checks, you will be fine.
Old January 11th, 2008, 09:39 AM   #7
Speedstang302's Avatar
13.64@101mph
idk about NH but mass is dumping emissions for 96 older cars this october...mass only does saftey test and tailpipe test right now..and Maine has nothing, so i dont see why NH would!!!
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old January 11th, 2008, 10:38 AM   #8
1991 GT Vert w/stuff
Evil Intent is on a distinguished road
you guys are lucky, we are getting screwed in California (there are a few exemptions based on the county, not mine though), a couple years back, the liberal nazis changed the law, so as of right now, all cars 1976 and newer are required to have a smog check every two years with a sniffer, rolling dyno, and in depth visual (including a timing check). if you are a gross polluter, then you have to get tested every year. that being said, i have a 1991 vert with Magnaflow H pipe with two high flow cats, shorty headers and dumped two chamber flows that passes smog every time.
91' Convertible, T-56, Cage, Aluminum Flywheel, Passes Smog on 87 Octane
Threads Similar to: 1990 Emissions Question
VA Emissions Question Cricket The Clubhouse 16 April 22nd, 2008 07:48 PM
1990 Mercedes 300 SL question stanglifemike All Other Vehicles 2 January 14th, 2008 11:15 PM
1990 5.0 Timing Question RMBillings 5.0 Mustangs 5 August 4th, 2007 11:04 PM
1990 5.0 LX vs. 1990 GT Ga_50_foxbody 5.0 Mustangs 8 January 16th, 2007 12:16 PM
Emissions stuff question cobralini 5.0 Mustangs 4 June 1st, 2006 10:52 PM
