1994 Mustang GT
Cant tell what codes mean
there are just so many of them I got 33182822172176 for koeo and 4117117 for koer
1994 Mustang GT
ya but what is my code out of all those numbers
#4 | |
KOEO: 182 ... ... 172 176 KOER: 117 (the 4 flashes at the beginning just indicate that it is an 8 cylinder engine) i would give it another try. after a little practice it gets much easier. the key is to remember: there will be a very quick series of flashes at the beginning that you should ignore, then a few codes will be output, then a long solid "seperator" flash, then a few more codes. once the KOER test is started there will be 4 flashes indicating the number of cylinders the engine has, then the codes will be output. from what i can tell you have a few codes related to both of your o2 sensors. also you have one for the ECT sensor. next time make sure you warm the engine up very well before the test. it is actually a good sign that you only had the ECT code for the running test. what symptoms are you having, or are you just checking things out? |
Big timin' in a small town
Wow I havent ever used that kind of scanner before. Guess I got spoiled working at a Ford dealer and using their scan tools on my car
#6 | |
...and its free
I did mine for free too
pluged it in scanned read the codes. Told me I had emmisions no shit I dont have cats. Then I read the fuel trim data checked that out and done.Free
obd2 vs obd1. there is no jumper method for obd2.
OBD 1 thats what my car has. And I can do OBD2 for free too. But thats for my cars only.
#10 | |
1994 Mustang GT
check codes again and post up what you get. its sounding like an o2 sensor issue but at $40 apiece i'm not about to guess at it. if you can, record a video of the codes flashing and post the video up.
1994 Mustang GT
I took a video of my codes and this is what I got, I hope someone can tell me what it means.
KOEO Video of KOEO - Photobucket - Video and Image Hosting and KOER Video of KOER - Photobucket - Video and Image Hosting |
Threads Similar to: Cant tell what codes mean
| CEL came on. Codes | JASonic | The Clubhouse | 2 | July 27th, 2007 06:57 PM |
| need help with these codes | chadjones99 | 5.0 Mustangs | 3 | June 20th, 2007 01:57 AM |
| codes help? | superbeef1000 | 99-04 | 12 | February 3rd, 2007 07:54 AM |
| Too many codes. Need help..... bad!!! | 88Horseman | 5.0 Mustangs | 1 | October 22nd, 2006 04:47 AM |
| iac and codes | cali 5.0 | 5.0 Mustangs | 4 | August 8th, 2006 03:04 PM |
