MAF sensor
Old January 13th, 2008, 01:21 AM   #1
e3sean's Avatar
1988 lx
9.68@142
MAF sensor
i am loosing my mind trying to find a mas air sensor...i herd C&L suck so i am avoiding them but they seem to be the only sensor that has sizes for differnt injectors. i found a few cobra 70 mm sensors but they are for 19lb injectors and i have 39 lb
can i get some info on what meters you 347 guys are running and how u like them? also what years MAF can fit my FOX??
Old January 13th, 2008, 01:24 AM   #2
e3sean's Avatar
1988 lx
9.68@142
oh snap i found a 39 lb injector maf off an 03 cobra which is where my injectors are off of..will my plug fir that if not is there an adaptor??
Old January 13th, 2008, 01:45 AM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
I think the plug wont fit but the wires can be cut and spliced.
Old January 13th, 2008, 01:49 AM   #4
e3sean's Avatar
1988 lx
9.68@142
i was looking at that i think if i can find the plug i could make it work i would just have to find the wireing diagram...
Old January 13th, 2008, 02:30 AM   #5
TENGRAM is on a distinguished road
its not gonna be very accurate and i'd be surprised if the car ran even close to right. the injector calibration is in the ECM. aftermarket meter's manipulate the signal to make it work for different injectors but a stock cobra meter is going to flood your engine even if it can be wired up. with 39lb injectors any aftermarket MAF is going to be less than accurate. best bet would be to buy a tuner like the tweecer and set up your MAF tables with info provided by the tweecer group and other sources. besides, you're at a point now where you have a lot to gain by tuning it.
89 GT t5 3.73
www.my5oh.com/
Old January 13th, 2008, 08:50 AM   #6
408gt91's Avatar
408gt91 is on a distinguished road
Mass-FloEFI Inc. Like i said before <---Pro-m Racing can calibrate to fit your need.
I would'nt use anything else.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old January 13th, 2008, 11:50 AM   #7
Speedstang302's Avatar
13.64@101mph
yeah pro-m's are nice units...and c&ls arent that bad...and they sell calibration tubes so you can run w/e injectors you want with them!!!
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old January 15th, 2008, 02:53 AM   #8
e3sean's Avatar
1988 lx
9.68@142
eBay Motors: 95mm pro-m mass air flow meter ford lightning (item 230210807503 end time Jan-14-08 21:12:45 PST)
i won this one today.. now all i have to do is get the adaptor and get it calibrated
Old January 15th, 2008, 09:50 AM   #9
13.64@101mph
95mm jesus you running 8000hp?
Old January 15th, 2008, 11:24 AM   #10
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
it shouldnt hurt anything being that big though should it
Old January 15th, 2008, 01:10 PM   #11
e3sean's Avatar
1988 lx
9.68@142
nope i was told to get the biggest one i could find i was only looking for a 75 mm but i couldnt beat $50 for a $379 maf sensor
Threads Similar to: MAF sensor
Sensor Help nHuman 96-98 3 December 28th, 2007 03:56 PM
What Can I Use To Get An O2 Sensor Out, Help! tjames V6 Mustangs 18 December 18th, 2007 05:02 PM
MAF Sensor help..... squirt 5.0 Mustangs 4 April 17th, 2007 12:39 AM
TPS Sensor bigbadtalontsi 5.0 Mustangs 0 March 27th, 2007 08:47 PM
MAP sensor ROBBED666 2005 - 2010 0 October 9th, 2006 03:12 PM
