Look Ma! My First Post!
engine problems
I have a 94 Mustang 5.0. I'm having a problem while driving. While slowing down to stop at an intersection,the engine will shut off as long as it is in gear. However, if it is out of gear it will run properly. Any commits accepted.
1987 Mustang GT
idle problem??? Not to sure on that one, is it a 5 speed?
The Razor's Edge
if its a 5 speed it could be your clutch is bad or needs to be adjusted
Yeah, could be your clutch isn't disengaging completely. Try pulling up on the clutch pedal to adjust, or get a firewall adjuster. Could also be a warped pressure plate.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1987 Mustang GT
If I remember correctly there is a vss sensor in the trans on a 5 speed that controls the idle when you coming to a stop. It is in the tail section of the trans.
Threads Similar to: engine problems
| Engine Problems? | James | 99-04 | 14 | March 2nd, 2011 02:20 AM |
| Help! (Engine Problems) | 97ponylover | Modular Mustangs | 13 | February 9th, 2009 11:13 PM |
| engine problems? | B.A.M302 | 5.0 Mustangs | 5 | September 5th, 2007 12:49 AM |
| engine problems? | B.A.M302 | 5.0 Mustangs | 7 | June 5th, 2007 01:27 PM |
| Engine codes and ECU problems? | wilecoyote | 96-98 | 6 | June 9th, 2006 09:02 AM |
