Need Help Reading Codes
Old September 12th, 2006, 11:20 PM   #1
chadjones99's Avatar
chadjones99 is on a distinguished road
found codes
Hello, well i ran some codes tonight.
i tried before but code reader did not work because i did not hook up the extra wire.
so here is what i got if i read it right
key on engine off
81
82
85
95
key on engine on
42
33
thats it.. how can i reset this so i can see if these are old codes or new.. i have a battery disconnect switch and turn battery to car off at night. should that reset it ?
thanks
chad
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old September 13th, 2006, 12:51 AM   #2
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
reset your computer by unhooking the battery for about 15 minutes and then runn your car for a while and it will register only the relevent codes,
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Old September 13th, 2006, 02:26 AM   #3
Bill is on a distinguished road
81-TAD or AM-2 (Thermactor Air Diverter)/ Secondary Air Injection Bypass (AIRB) solenoid circuit failure, or SCVNT (Speed Control Vent) circuit failure (IVSC test)
82-TAB or AM-1 (Thermactor Air Bypass)/ Secondary Air Injection Diverter (AIRD) solenoid circuit failure, or SCVAC (Speed Control Vacuum) circuit failure (IVSC test).
85-CANP (Canister Purge) solenoid circuit failure
95-Fuel Pump Monitor circuit problems, processor to pump motor ground. Suspect inertia switch, FP relay, harness.
key on engine on
42-EGO/HO2S sensor voltage always above "rich" on bank #1 (c*): No EGO sensor rich/lean transitions detected, bank #1.
33-Insufficient EGR flow detected.
and +1 what the other guy said about reseting the computer. drive for about 10 miles and it should reset its self
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Threads Similar to: Need Help Reading Codes
For your reading pleasure ... MeZ 99-04 22 July 30th, 2007 10:51 AM
TPS reading backwards blakeasaurusrex 96-98 4 July 10th, 2007 11:40 PM
Still reading cold YNOT 5.0 Mustangs 13 April 29th, 2007 07:49 PM
Was reading through the TSB's.... DrHolliday 99-04 2 March 31st, 2007 09:18 AM
Speedometer reading odd... homebrewed 5.0 Mustangs 5 March 7th, 2007 09:20 PM
