1992 Lx
11.39@119.24
19lb injectors big enough with trickflow h/c/i kit?
Saving up for the kit but it would be nice to not have to buy injectors fuel pump and a new maf
Big timin' in a small town
No put in some 24lb injectors with those you wont need a new fuel pump either
1992 LX 5.0
I've been told you can "get by" with 19lb injectors and the trick flow top end kit. I don't know for fact, but should be able to tell you by next week, as we will still have the 19lb injectors in ours for a short period of time. I didn't want to buy 24lb injectors and then turn right around and have to buy larger injectors when we buy a supercharger.
Long run you will want to have larger injectors, is the trick flow kit the end of the road for your stang? or do you have other stuff planned in the near future? |
you could but they would be near 100% duty cycle...24#ers and a bigger maf would be ideal....as for a fuel pump...put in a 255lph and call it DONE...easy swap...i did one in 2 hours by myself and i am not really that good mechanically speaking.
1992 Lx
11.39@119.24
yeah i figured they would be near full cycle, i dont plan on anything for awhile after the tf kit, but if i do put the 24lb injectors and pump, wouldnt i have to get the car dynoed and tuned so get the a/f ratios corrected?
1992 LX 5.0
1991 mustang LX
+1 just get it over with.
GT-40x heads cobra upper and lower intake manifold BBK CAI MSD 6A 3/4 cam 3.73's ford racing headers o/r MAC H-pipe flowmaster catbacks 50's (coming soon nitto 245/50/16's, a1000 fuel pump, and super 44's) |
1992 Lx
11.39@119.24
k k thanks guys, oh and new to the domestics, how much does dyno and tuning time run on a foxbody? For the new map and dyno time on my wrx it was close to 800 bucks
It is about $150 an hour around here...If you are not worried about getting every single bit of HP out of the car, you can probably just get it street tuned and get out of there in a couple hours.
1992 LX 5.0
Going to be different for different areas and tuners. The place near hear charges $60 for 3 dyno pulls, or $85 an hour to keep the dyno going if you need tuning. I've never rented it for more than an hour, so not sure if you get a break as you get higher.
You should run 24lb injectors but you can run the 19lb injectors for now. I've run as fast as 11.59 with 19lb injectors already. Not optimal but possible.
13.64@101mph
just do 24lbers...you can find nice used ones for less than $150
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
I will never buy used injectors again. Thats like buying used underwear.
1990 LX hatch
This is true. Most of the time you buy used injectors and there bad, it's because shit got into the injector during the time they were pulled and re installed.
Is there something wrong with buying used underwear?????????????
Naaaah man! If it belonged to Jennifer Love Hewitt!
13.64@101mph
so that its he admits he wears womens underwear..
13.64@101mph
its not me so im set
Hey, i never admitted to wearing womans underwear. Im weird, but not that damn weird. If a hot celebrity sent you a pair of her underwear, you would turn it down? I think not. Thats all i be sayin
Threads Similar to: 19lb injectors big enough with trickflow h/c/i kit?
| Trickflow for 4.6 | mustang03GT | 99-04 | 21 | August 5th, 2007 09:14 PM |
| 70mm mass air flow 94/95 Mustang GT 5.0 19lb SN95 MAF | stang94 | 94-95 | 8 | April 18th, 2007 07:31 AM |
