Injector size HELP!
Old January 14th, 2008, 07:24 AM   #1
NOSLO5.0's Avatar
1995 vert. x-mod
na
NOSLO5.0 is on a distinguished road
Arrow
Injector size HELP!
I have a 347 stroker, 185 AFR heads, reconfigured GT-40 intake, X-303 cam, 75MM throttle body, 90MM MAS. Right now I have a set of 30LB injectors.
Before I dyno this up & run it for first time, Would it be a good idea to run a slightly bigger injector to start with so I don't run the risk of "pegging" the 30 pounders!
JASON ERIC BRESMON 1979-2004
TILL WE RIDE AGAIN
A candle that burns twice as bright - lasts half as long
Old January 14th, 2008, 07:56 AM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
the 30s should be fine.
Old January 14th, 2008, 08:28 AM   #3
sneezingfox's Avatar
sneezingfox is on a distinguished road
Good to go. Get that beast on the dyno and see what she does!
Old January 14th, 2008, 09:55 AM   #4
Speedstang302's Avatar
13.64@101mph
yep 30lbers are perfect...36lbers wouldnt hurt you to much but i'd stick w/ the 30s
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old January 14th, 2008, 11:20 AM   #5
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
I doubt you'll "peg" the 30lb'ers. Their good for 400+hp.
Old January 18th, 2008, 12:47 AM   #6
problemCOBRA94's Avatar
1994 Mustang Cobra
it runs now. Kinda...
problemCOBRA94 is on a distinguished road
Send a message via Yahoo to problemCOBRA94
what is your horsepower goal? over 400 and I would say step up to 36 if you are NA.
Does that gt-40 intake feed air to those heads and the 347?
Old January 18th, 2008, 09:52 AM   #7
nolife's Avatar
91GT, 88GT, 02GT
Not sure about the heads but MM&FF did an intake comparisons with 347. A ported and polished GT40 was in the mix. The peak HP and torque was lower than the other intakes but the average across the range was close. This was a magazine article, your results may be different.
Super Intake Shootout - Muscle Mustangs and Fast Fords
Threads Similar to: Injector size HELP!
Injector size 5.0 Junky 5.0 Mustangs 65 December 26th, 2007 03:14 AM
Injector Size imported_Gt_Jay 5.0 Mustangs 12 November 14th, 2007 02:09 PM
Injector Size mmvi V6 Mustangs 11 November 10th, 2007 04:11 PM
Suggested injector size?? jam77 5.0 Mustangs 12 October 17th, 2007 12:40 AM
injector size? 92_LX_5.0 5.0 Mustangs 6 February 11th, 2007 01:42 AM
