looking for some answers
OK, I have searched but there is too much info Im needing to find out for sure what I'm needing to know. I figured it would be easier to ask and some of the more experienced to come and answer for me. Im planning a build so Im trying to figure out a money plan.
1)Stroking the motor out 331vs347. I need to know the pro's and con's. Im looking for a realiable/strip car if that makes since. Want to have fun at the track and be reliable on long trips if needed. 2)What heads are the best for a forced induction application? I have searched and came across a few but didnt determine which were better. 3)Which intake manifolds are best? Again, I have come up with multiple findings. Thanks in advance. |
1) 347
2) There are a lot, 61-64+ cc combustion chambers are nice for forced induction 3) TFS R, Holley sytemax 2, victor 5.0, etc...
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#3 | |
The Razor's Edge
+1 |
#4 | |
1) ok, but I wanted pro's and con's on each 2) certain names to look for? or are they about the same? 3)Are they about equal in power, just different designing and pricing? |
The Razor's Edge
tomorrow my dear sir.....
1) 331
pros: its bigger than a 302 Cons: smaller than a 347 347 pros: bigger than a 302 cons: not as big as a 408 No real difference between a 331 and 347 stroker other than the 16 cubic inches and about 20 hp. Also the compression will be a bit higher with a 347, so something to keep in mind if you are planning forced induction 2) Canfield, TFS, edelbrock all make great heads. AFRs might have too small of combustion chambers without some CNC work for forced induction...depends on how much boost you want to run 3)Holley systemax tends to produce the most power NA, but forced induction has a tendency to equalize similarly matched intakes.
#7 | |
#8 | |
#9 | |
BTW, seeing stangzilla post on here reminded me that the spyder intake might also be a good choice for a forced induction 347.
#10 | |
Thanks, but I read that article years ago, it is a decent comparo. You should note that the GT-40 lower was ported in that comparo. The lower isn't great, especially the #1 and #5 runners. I you want to run a GT-40, lower porting is highly recommended.
13.64@101mph
i would quote something and +1 it ryan but that all was great..couldnt have done it better myself..except does anyone run brodix heads on small block ford strokers?
Yep. Brodix is a popular head.
1986 lx notch
9.98 @ 135
dss claims that a 331 will make more power then a 347, they claim that the 347 suffers from more frictional losses something about the additional stroke causing the bottom of the piston to come out of the bore and being pushed more against the cylinder wall instead of up the bore. they claim the 331 to be worth some 30 more hp and advise that the 347 should be mainly used in heavier cars with autos and less gear. personally i'd save for a windsor swap, much better block, better head sealing, bigger head bolts, more room to grow, more torque
#14 | |
#15 | |
As for a 331 making more power, I have talked to the guys at DSS many times and even visited their facility a couple times. I've never heard them say anything about a 331 making more power than a 347. If they did say that, I'd laugh and ask to see the dyno numbers. By that logic a 306 makes more power than a 331, so why go with a stroker kit at all. A lot of people go the 331 route because it produces lower compression numbers without having to have a huge dish which typically promotes detonation. While they might put a little less side load on the piston than a 347, I don't think it makes a difference longevity wise.
Threads Similar to: looking for some answers
| Newbie looking for answers! | TheBrat | 5.0 Mustangs | 84 | January 16th, 2008 07:03 PM |
| Need answers | Buck01 | 99-04 | 0 | November 8th, 2007 02:27 PM |
| Need help quick . no bs answers please. | Youngin | The Clubhouse | 46 | October 10th, 2007 08:30 PM |
| Nitrous answers | blackie | Northeast | 0 | May 5th, 2007 07:31 PM |
| Gear Answers | HMUSN | 99-04 | 0 | November 13th, 2006 03:03 PM |
