dropping fuel cell, few questions
Old January 16th, 2008, 06:47 PM   #1
kuskye25's Avatar
kuskye25 is on a distinguished road
Dropping my fuel cell tomorrow to fix the leak its had for a long time, I'm wondering what all i should replace while im in there. This summer I'm rebuilding it also "it'll be my first rebuild I've done". Thinking in the range of 300-350hp.
Anyway I figure I'll fix whats leaking, replace fuel filter. Then what else should i do, if anything?
Just to hit it all in one post, also I'll be draining my manual trans and replacing the rear seal at the same time as the fuel cell. Does the rear seal pop out easy if the driveshaft is dropped out?
Thanks
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears
'93 LX 4-banger 78k miles
Old January 17th, 2008, 11:03 AM   #2
kuskye25's Avatar
k
Old January 17th, 2008, 11:07 AM   #3
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
if your gonna start a build you might go ahead and put a good performance fuel pump in there
Old January 17th, 2008, 11:11 AM   #4
kuskye25's Avatar
ok so new fuel pump any sujestions on good but not to expensive one
Old January 17th, 2008, 11:19 AM   #5
kuskye25's Avatar
ok guys thanks im going to do this now i guess ill see if napa carrys something better then the stock fuel pump...
Old January 17th, 2008, 01:25 PM   #6
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
this might be a little late, but get either a 190 or 255 lb pump from summit racing, ( summit racing.com ) they are around 120 - 130 bucks and will be plenty good for any future mods, i think most auto parts stores only carry stock 88 or " cobra " pumps at 110 lb , btw both 4 cyl and 5.0s had the same 88 lb pump. i'd recommed a bbk, i've used these before and had no probs, don't get the summit one, they're ususally cheap
Old January 17th, 2008, 03:14 PM   #7
1992 LX 5.0
Devine is on a distinguished road
Might as well do the fuel filter too while you're in the area.
Like mentioned above, might as well go ahead and put a 255lph fuel pump in. They're not much more expensive.
Old January 17th, 2008, 03:33 PM   #8
1990 Mustang GT
he mentioned replacing the fuel filter in the first post
Old January 17th, 2008, 03:34 PM   #9
kuskye25's Avatar
yeah so all i could find locally is stock pumps so i guess i lose and have to take it apart again sometime when i upgrade. is nice to have a non-leaking fuel cell finally, and a non-leaky transmission
Old January 17th, 2008, 03:37 PM   #10
1990 Mustang GT
dang man i guess you work pretty fast.....where are you at cus its cold in arkansas so it cant be warm very many places
Old January 17th, 2008, 03:42 PM   #11
kuskye25's Avatar
indiana but i was able to use my buddies garage and lift. but yes is snow on the ground here and about 30 degrees, dont mind it cept when it comes to driving and working on my car then i hate it with a passion
Old January 17th, 2008, 04:06 PM   #12
1990 Mustang GT
well the lift explains how you got it done so quick and the garage definitely helps since its snowing there
Old January 17th, 2008, 04:08 PM   #13
kuskye25's Avatar
yes its an automotive shop and he sometimes can rent his bays to me and he helps me. Hes who is going to help me with the rebuilt this summer.
Threads Similar to: dropping fuel cell, few questions
Fuel Cell in 95 Mustang dreamr 5.0 Mustangs 10 November 5th, 2007 03:00 PM
Fuel injector install questions? bossman2kgt 99-04 7 July 12th, 2007 03:14 AM
fuel pump questions - wtf? blakeasaurusrex 96-98 7 July 7th, 2007 01:45 PM
Fuel Cell Installation In 2005+ GT gx1856 2005 - 2010 1 April 13th, 2007 08:35 AM
Fuel Injection Questions redsMULLT1 All Other Vehicles 5 February 10th, 2006 11:32 AM
