351 windsor
Old January 16th, 2008, 06:48 PM   #1
5mustang0 is on a distinguished road
351 windsor
hi guys i was wondering how to tell if an engine is a 351 windsor or not and if it is none roller or roller
Old January 16th, 2008, 06:54 PM   #2
1987 ford mustang gt
well see when shes done
casting number
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old January 16th, 2008, 06:57 PM   #3
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Easiest way to tell if it is a 302 or 351 is the deck height. On a 302 the deck is even with the top of the water jacket for the timing cover. The 351 has a 1" gap between the deck and that water jacket.
As for being roller or not the easiest way to tell is to look at the lifters if the intake is off. If you can't rip it apart then your going to have to start looking at the casting numbers.
TT Build in progress.......
Old January 16th, 2008, 06:57 PM   #4
where is the caster number located at it's in a truck i belive the truck is a 1964 or around that year it was from south dakota and it has an electric cord coming out from it like a diesel truck would and the exhaust manufolds r connected to each other in front of the block
Old January 16th, 2008, 08:00 PM   #5
Speedstang302's Avatar
13.64@101mph
What? casting number? go to google and type in 351w casting numbers..it will tell you where they are and when you find them what they mean..i'll try and find a link
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old January 16th, 2008, 08:02 PM   #6
13.64@101mph
FORDification.com - Ford V8 Engine Identification
this place is usually a great help
Old January 16th, 2008, 08:04 PM   #7
ryans88gt's Avatar
Only 94 and newer 351w were roller, so that is not a roller.
Old January 16th, 2008, 08:10 PM   #8
13.64@101mph
but they make roller conversions for all 351w's...
Old January 16th, 2008, 08:14 PM   #9
ryans88gt's Avatar
you can't make a non-roller block into a roller block.
But you can buy the $500 retrofit roller lifters. So if you are looking for a roller, it is cheaper to start with a roller block.
Old January 16th, 2008, 08:19 PM   #10
13.64@101mph
"But you can buy the $500 retrofit roller lifters." So if you are looking for a roller, it is cheaper to start with a roller block.
that is what i meant you're right...but i'd rather a roller to begin with..thats another reason why i dont wanna do 351w swap. i'll stick to roller 5.0's!!!
Old January 16th, 2008, 08:23 PM   #11
ryans88gt's Avatar
Why? You can get a roller short block 408 with forged internals balanced and ready to build for well under $2500.
I'll help you through it, if you need help.
Old January 16th, 2008, 08:46 PM   #12
13.64@101mph
fudge that...if i do do the stroker 302..and i go dart or boss block its either a 347 or 363..btw that procharger? on the blue car?
Old January 16th, 2008, 08:49 PM   #13
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Not only will you have a stronger block with the 351 but retrofit roller rockers aren't that expensive.....
Old January 16th, 2008, 08:50 PM   #14
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
yes you can make non-roller block rollers...... all it requires is drilling and tapping holes for the hold downs.
Old January 16th, 2008, 08:56 PM   #15
13.64@101mph
351w stronger than a dart or boss 302 block?
Old January 16th, 2008, 08:56 PM   #16
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
roller 351s start with the casting # F4TE , i just got one out of a boat ( i'm going to build a 408 as soon as i win the lotto ) my current motor is only a flat tappet and i really wanted a stroked motor with a roller cam
Old January 16th, 2008, 09:03 PM   #17
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
i think he was just referring to the stock 302 block..
Old January 16th, 2008, 09:04 PM   #18
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
never said that..... but yes its stronger than a 302.
Old January 16th, 2008, 09:06 PM   #19
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
And why does the motor being a roller mean that much to you anyway? You can still make tons of power with a non-roller.....
Old January 16th, 2008, 09:07 PM   #20
woody1 is on a distinguished road
people are too cheap to buy a link bar hyd lifter and small base cams using the stock hyd roller lifter are junk, thats why
Threads Similar to: 351 windsor
windsor or BB? sloppyjosey 5.0 Mustangs 18 October 26th, 2007 12:25 PM
5.8 windsor gt40 1966 5.0 Mustangs 2 July 5th, 2007 09:57 AM
351 Windsor HP? 351W94GT 96-98 11 June 29th, 2007 08:14 PM
351 Windsor dragpipe General Tech 5 February 28th, 2007 06:40 PM
351 windsor 351stng 5.0 Mustangs 7 January 10th, 2007 08:44 AM
