351 Cleveland
LinkBack (2) Thread Tools
Old January 16th, 2008, 08:45 PM   2 links from elsewhere to this Post. Click to view. #1
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
351 Cleveland
I can get a mint 0 miles WORKED 351 cleveland motor. From my uncle. For Nothing. Is it worth putting it into my stang? id like to get off of this 5 slow motor.. just kidding its a stout motor id just like to bump up the ci. Anyone know how involved this swap would be?
Old January 16th, 2008, 08:49 PM   #2
Speedstang302's Avatar
13.64@101mph
im pretty sure its same basic swap as 351w's...ask ryan he has one in his red/black car...
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old January 18th, 2008, 12:15 PM   #3
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
What year Cleveland? 2v, 4v?
Its basically the same swap as the windsor. You'll need a K-member, oil pan, headers.. (if your going carbed from EFI you'll need a throttle linkage) The Cleves have a different cooling configuration, so im not 100% sure, but i think you'll need different radiator hoses and radiator.
Man, more and more people are asking about cleves in foxes, maybe i should put mine in a fox.
Old January 18th, 2008, 12:24 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
There is room, but not for headers, not with out some cutting.
Old January 18th, 2008, 12:26 PM   #5
Goblin's Avatar
88mm
What do you have to cut?
Old January 18th, 2008, 12:35 PM   #6
ryans88gt's Avatar
No the headers will fit if you get the correct swap headers without any cutting.
Also I'm not sure about the K-member needing to be replaced, i think you can find a rear sump pan that will work...maybe?
Also the EFI linkage will work on a carb car. I am still using my EFI linkage on my 88 gt. You just put a big loop in the linkage and it fits perfect.
Old January 18th, 2008, 12:42 PM   #7
Goblin's Avatar
88mm
I didnt know about the linkage working, i always thought you needed a different linkage for the carb.
I know that headers can be made to work without cutting, this is why i asked. As far as the k-member/oil pan issue.. my only argument is... What can swapping the k-member to a tubular one hurt? Your putting your front suspension on a diet, which is good because the cleve has a bit more heft than a 5.0. I really dont know of a rear sump pan that will work with the factory k-member.... i would like to know if there is.
Old January 18th, 2008, 01:30 PM   #8
ryans88gt's Avatar
Yeah, it wouldn't hurt to do a K-member..
It appears as though there is an oil pan and headers that will work...
Ford Rear Sump Strip and Road Race and Strip Oil Pans Look halfway down the page
351C headers and oil pan fox body - NMRA Ford Nationals Series Forum
Old January 18th, 2008, 01:38 PM   #9
Goblin's Avatar
88mm
Sweet. Im really intersted to see if that pan would work with a stock K-member. It doesnt say if you need an aftermarket K-member... so maybe that means you dont need one?
Old January 18th, 2008, 01:41 PM   #10
ryans88gt's Avatar
It looks like it is designed to work with a stock K-member, but it does say you need aftermarket motor mounts
I guarantee it will fit with a flaming river rack. That rack gives you almost an inch of extra clearance.
Old January 18th, 2008, 01:44 PM   #11
Goblin's Avatar
88mm
Right.
What does your GT run by the way, with the cleve? And whats done to yours?
Old January 18th, 2008, 01:54 PM   #12
ryans88gt's Avatar
It runs mid 11s @ 120 mph with 1.5 60 foots. The heads currently on there are as cast 4V closed chamber heads, casting flash and everything, modified for adjustable valve train.
Its a 351 windsor block, 0.040 over with KB pistons, stock rods, stock crank, 1 3/4" headers, and a B&A track boss intake, with a mighty demon 650, the cam is a flat hydraulic that tops out at about 5500 rpms. Solid roller maybe in the near future to wake it up a little bit. I'm also thinking about some port work on the heads to close things up a little. My intakes cc were something like 255 or 265 ccs.
Old January 18th, 2008, 01:58 PM   #13
Goblin's Avatar
88mm
A 9.5" windsor block? You have to run a special intake right?
Thats an impressive trap speed for 11.50. How much does the engine weigh compared to a 5.0?
Old January 18th, 2008, 02:07 PM   #14
ryans88gt's Avatar
Well that's a good question as far as the weight. I estimate that the cleveland heads weigh almost 75 lbs each when fully assembled. So I bet the engine weighs at least 150 lbs more than a 5.0. But you are removing the upper intake weight, all the sensors, the wiring harness weighs like 25 lbs, the smog and emissions bull crap, I also removed the PS and AC. My 88 weighs in at 3090 lbs with a full interior, stereo, 8 point roll cage, subframes, 4 core radiator, and stock seats. Still has the bumper and support and foglights and all that.
Yeah I am using the 9.5 windsor block with a B&A track boss intake. You can use a 9.2 windsor aftermarket block with a cleveland intake and a valley pan. The headers work the same with either block. the 0.3 inches doesn't make much of a difference, I am using standard 351C 4V swap headers.
Oh yeah as far as the trap speed, it is a 5 speed car and I don't powershift. So I probably could see 11.0s with some powershifting, but I like my T5.
Old January 18th, 2008, 02:09 PM   #15
woody1 is on a distinguished road
dont close the intake ports at all, use cam timing to overcome that port dimension along with rpm
Old January 18th, 2008, 02:20 PM   #16
Goblin's Avatar
88mm
Do you have any pictures of this?
I was expecting more than 150lbs, but thats really not bad at all considering the fact that swapping to a tubular K-member, A-arms and coil overs drops nearly 100lbs off the front end. Plus yanking all the junk you said above. I was really worried about weight. Do you have an aftermarket steering rack seeings as you dont have PS?
Powershifting + T5 = Not a good situation... the 120 trap speed makes sense now.
Old January 18th, 2008, 02:24 PM   #17
ryans88gt's Avatar
They kinda bell at the opening, I've heard that by just getting rid of the bell you only loose a few CFM and gain a bunch of velocity. I've also heard they work great @ 8000 rpms as they are or on a 408 without any filling. I don't really have any problems with torque, it has plenty of low end.
Just seems like a lot of people fill with epoxy and then work on a flow bench to port the epoxy into a fast and efficient runner. I don't know, mostly I want the exhaust side to be cleaned up, cause it is like a 90 degree turn. You know of anyone that does good port work on 351C heads?
Old January 18th, 2008, 03:27 PM   #18
The Razor's Edge
White Thunder's Avatar
why not get an aftermaket k member and slice 50 pounds of the nose of your car...there not crazy expensive.....
founder of the FTN Club
Old January 18th, 2008, 05:20 PM   #19
ryans88gt's Avatar
I have lots of pictures at home of the whole build, but none at work. Remind me later and I'll send you some pics.
I originally just kept my PS rack with no pump, but that got old in a hurry. I switched to a flaming river rack and it only requires about 25% more effort that it did with the PS intact. I am still using the stock K member, but a fiberglass hood and bumper support removal would make the car lighter than it started out as.
Old January 18th, 2008, 05:39 PM   #20
Goblin's Avatar
88mm
Sweet, i'd love to see them. I really think using my cleve for a fox build up would cool, and different. Cheap? No, but still different. What ratio is your steering?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/51162-351-cleveland.html
DFWstangs Forums - 351C fox swap This thread Refback October 14th, 2008 09:08 PM
DFWstangs Forums - 351C fox swap This thread Refback October 14th, 2008 02:43 PM
Threads Similar to: 351 Cleveland
Cleveland Goblin 5.0 Mustangs 23 January 8th, 2008 05:14 PM
351 Cleveland Cobra Jet 65 B/FX Classic Mustangs 6 January 6th, 2008 09:41 PM
351 Cleveland 4v Suggestions? Sixtyeight Classic Mustangs 3 January 1st, 2008 12:02 PM
New From Cleveland, Ohio thlsislt New Members Introductions 13 December 27th, 2007 08:30 PM
351 cleveland ih8chevy 5.0 Mustangs 15 December 8th, 2006 03:26 PM
