2004 Mach 1
Limited slip
Hello all I heard from some ppl i've talked to that you all are very helpful so i thought id give you all a try. I have a 90 lx 5.0 I was told it doesn't have a posi in it. So I decided to put a limited slip diff in it all the places around were I live use a brand called American Axle. Has anyone ever heard of them and if so are they any good? If not does anyone have a good suggestion for one? The car is mostly used on street but will see track some.
1992 LX 5.0
it comes with a traction lock differential, so you shouldn't be spinning a single tire unless the t-loc needs a rebuild
2006 Mustang GT
Never heard of that brand. I would go with a Eaton
![]() 2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII |
#4 | |
Ford Racing Performance Parts [Differentials] look down twards the bottom of that page for a couple rebuild options |
1988 Ford Mustang GT
8.372@82.8 1/8mile w/1.825 60'
Go on summit and get an eaton then take it to the people to put on.
I never thought I would own a mustang!!! |
oh yea only if your diff. is not working get the eaton.Check it by doing a burnout on a street then get out and see if both tires left there mark.
#7 | |
2004 Mach 1
Whats the stock spline is it 28 or 31?
28
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1987 ford mustang gt
well see when shes done
you can add a clutch to it when you rebuild it and it will bit harder might chirp when you go around the corner this is what i plan to do anyone done this
or you can get the carbon disc rebuild....that will make it more hardcore and last longer
how much $$$$ and where?
that same link that i posted earlier
The Razor's Edge
can't you weld it....or am i thinking of something else
you can weld up the spider gears and make a full locker.....woulnt recommend
The Razor's Edge
why not?
cus you cant undo it.....the only time it would be good is for a full drag car and then i just think it would be worth it to get a spool......i actually did see them do some like that on extreme 4x4 one day.....it was a budget crawler build or something like that
The Razor's Edge
yeah thats where i seen it too...i think it was muscle car though
Threads Similar to: Limited slip
| limited slip? | cpork | V6 Mustangs | 7 | May 9th, 2007 03:36 PM |
| limited slip differential | burlingtonNC98GT | 96-98 | 6 | April 17th, 2007 01:54 PM |
| Limited slip diff? | energiesource | 99-04 | 6 | January 20th, 2007 03:35 AM |
| Limited Slip Differential | flattusmaximus78 | V6 Mustangs | 75 | September 28th, 2006 08:11 AM |
| Limited Slip | JRubin2000 | 99-04 | 6 | September 21st, 2006 05:59 PM |
