Nitrous Kit
Just bought a ZEX dry kit for my 93. I had a compucar wet kit on my 2001 about 4 years ago. Is the dry kit the way to go on a 93? or should I convert to the "wet" kit?
11.47@120.58
Dry is safer, go that route if you're already setup for it.
Dry kits are good. Wet kits can be dangerous on EFI cars because they tend to puddle fuel in an intake manifold that was designed to flow only air.
Thanks...still should pull 2 degrees of timing per 50 hp increase? Colder spark plug also?
2 degrees for every 50 is very safe. I used to run with 2 degrees pulled out spraying 150. 1 heat range colder than stock will be good.
Threads Similar to: Nitrous Kit
| Nitrous | Goblin | General Tech | 0 | November 12th, 2007 03:42 PM |
| nitrous | mustangboy8909 | 5.0 Mustangs | 6 | July 29th, 2007 09:33 PM |
| what do you think of nitrous | Badasstang281 | 99-04 | 51 | January 7th, 2007 06:07 AM |
| Nitrous ?'s | bwb3 | 5.0 Mustangs | 5 | November 27th, 2006 04:31 PM |
