98 Cobra
clutch update, if ne one cares
got new clutch in today, went smooth only problems were with the piolet (i cant spell just sound it out) when i hit it with a slide hammer the only part that came out was the freakin center of the bearing so i spent a little getting that bearing out, so far i havent had the same old problems with getting into first gear
my pilot bearing was a pain too. I ended up having to cut mine out with a salsaw cause my exhaust and motor got so hot the thing melted to the crank. lol that was an experience.
#3 | |
The Razor's Edge
in haynes it says put heavy grease in the pilot bearing and put i tight fitting metal rod hit it with a hammer and hydrolically(sp.?) push it out.
85 svo. work in progress
Yeah, that never works ^^^ The best way is to get the pilot bearing puller and slide hammer. Usually the center does come out and then you put the puller back in after the center comes out and slide hammer it some more. The only thing the grease trick is good for is making a huge mess everywhere.
Congrats on the clutch install 91cobra. Did you get the clutch cable adjusted correctly?
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
98 Cobra
yea using the slide hammer a second time on the outer part of the bearing didnt work, i had to take a cold chisel and hammer along one side of the bottom to work it out, once i started doin that it came right out.
so we went to dinner and i drove about what an average person usually does, and the clutch held with no problems |
yeah make sure you break it in for about 500 miles before you beat on it.
#8 | |
i used this method cuz the puller with the slide hammer kept slippin... the grease actually worked like a dream, after you do it once or twice its reall easy. you just have to repack it with grease everytime you hit it
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
Threads Similar to: clutch update, if ne one cares
| Tony heres my snowboard and for anyone else who cares | Drick | The Clubhouse | 31 | January 19th, 2008 04:32 PM |
| update pic of my 06 GT | GT33 | Pictures | 9 | September 16th, 2007 03:10 PM |
| Update on Nothing | MSTGGT00 | 99-04 | 6 | June 8th, 2007 10:53 PM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 02:33 PM |
