91 LX Refuses to Start
Old January 20th, 2008, 07:08 PM   #1
1991 5.0 LX 5spd
Uniflightstang is on a distinguished road
Send a message via Yahoo to Uniflightstang
Hey guys. I need help from you stang experts out there. My 91 LX just refuses to start. Here is what I have done to troubleshoot the problem in steps of course:
-Verified spark....all cylinders good
-Verified Timing #1 TDC
-Verified fuel pressure...all plugs new and wet
-Replaced TFI module on distributor
-Verified all engine compartment connections are connected
-Verified mass air sensor good with another new one I have
-Verified TPS sensor idle and WOT voltage
-Replaced battery with brand new Optima
-Replaced Cap, Rotor, and Coil
-Went through the EEC EFI troubleshooting procedure. Everything checks good.
-Replaced EEC and MAP Sensor
The car cranks but wont light off. It even smells like inormal exhaust when I try to crank it. The only thing left to replace would be the plug wires and the IAC sensor. Could a Faulty Ignition switch cause a no start condition? I think the next thing I'm going to try is Magic. Any help would be greatly appreciated. Thanks.
1991 LX 5.0 T5 3.73 gears, BBK Equal Length Headers, BBK Xpipe without Cats, Super 44 Flowmaster with catback, 70mm MAF, 70MM TB w/spacer, Ported upper and lower intake, and Steeda Triax shifter
Pilot/Avionics Manager
Old January 20th, 2008, 08:52 PM   #2
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
did u check firing order?
Old January 20th, 2008, 09:24 PM   #3
Speedstang302's Avatar
13.64@101mph
try arching the starter solenoid?
and how good is you're starter?
did you check all the grounds?
and yeah what firing order you running it on?
and you sure its at TDC and rotor is facing directly back?
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old January 20th, 2008, 09:45 PM   #4
13.64@101mph
you're right got that shit mixed up...fuel delivery?
Old January 20th, 2008, 09:59 PM   #5
1991 5.0 LX 5spd
Yes. You cant check the timing correctly without knowing the firing order. The car cranks but will not start
Old January 20th, 2008, 10:05 PM   #6
13.64@101mph
sounds like its electrical, has to do with timing and spark i bet...what degree of timing you running?
Old January 20th, 2008, 10:11 PM   #7
1991 5.0 LX 5spd
I think you are right speedstang. Stock at 10 degrees but I cant get it running to put the light on it.
Old January 20th, 2008, 10:17 PM   #8
13.64@101mph
are you running a cam? are you running really big fuel injectors by any means? just a few things that make em not start..but with a decent size cam i'd up the timing a couple degree's..just sounds like its 180* out...
Old January 20th, 2008, 11:14 PM   #9
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
I noticed that you said that your plugs were wet, if too wet it won't start. This just happened to me today and I couldn't get my 93 LX cranked it sounded like it wanted to but it would never do it. So I pulled the plugs and they were wet, bought a new set and it started right up. Hope this helps
Old January 20th, 2008, 11:30 PM   #10
91cobra5.0's Avatar
98 Cobra
i could be very wrong but if your plugs were wet with say water wouldnt that help it due to the fact that water is a conductant?
Old January 20th, 2008, 11:32 PM   #11
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
they would be wet with fuel because they aren't sparking
Old January 20th, 2008, 11:33 PM   #12
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
just a thought- but check for blocakge in your exhaust system.
Old January 21st, 2008, 11:34 AM   #13
1991 5.0 LX 5spd
Yes its correct.
Old January 21st, 2008, 11:36 AM   #14
1991 5.0 LX 5spd
Its a stocker. How does it get 180* out if I havent takend the distributor out.
Old January 21st, 2008, 11:36 AM   #15
1991 5.0 LX 5spd
Yeah. I already replaced the plugs. Same thing. NO start.
Old January 21st, 2008, 11:38 AM   #16
1991 5.0 LX 5spd
I dont know what that could be. I have bbk equal lengths/xpipe w/ no cats, and brand new flowmaster/catback.
Old January 21st, 2008, 02:20 PM   #17
13.64@101mph
i'd say get the timing upto 13-14* but you can get it started to do that..and idk im a little stumped myself...
Old January 21st, 2008, 02:30 PM   #18
ryans88gt's Avatar
By putting the distributor rotor on backwards...
Your plugs shouldn't be wet. If they are, what are they wet with? Fuel, oil, water? If they are wet with fuel, you are not getting enough spark, could be the coil or your timing or too much fuel pressure. If they are wet with oil or water, you have other problems like a blown head gasket. You need a fuel pressure gauge reading and a compression or leak down check.
Also there are 2 firing orders for 302s, make sure you are using the correct one. And timing and firing order aren't related and you can't set or check timing unless the car is running. If you moved the distributor at all, your timing is likely to be off. Try rotating it around a little bit at a time.
Old January 21st, 2008, 03:09 PM   #19
13.64@101mph
yeah its gotta be 180* out...make sure the rotor is facing directly back and the #1 spark plug boot on cap is straight back too...
Old January 21st, 2008, 04:56 PM   #20
rwfisher is on a distinguished road
It sounds to me like the timing chain could have jumped. If you have 106K on it without having a new chain, it could have jumped. Or is so totally stretched it is out of time.
Threads Similar to: 91 LX Refuses to Start
When Did The 8.8 Start? itschristorres8 5.0 Mustangs 9 December 10th, 2007 01:54 PM
Start up RPM hopper 5.0 Mustangs 8 May 10th, 2007 10:52 AM
New start .. Intake 96-98 4 February 20th, 2007 12:08 PM
won't start =-( wesbugg 96-98 2 January 29th, 2007 06:58 PM
Where to start? JBake V6 Mustangs 6 October 24th, 2006 12:43 AM
