98 Cobra
running lean
ok so i had to leave off the pipes and run headers until this wed. (ran out of time at the shop and had to get the car home so i didnt get the pipes back on) well now its running lean and i was just curiouse as to why that was happening, is it becuase that there is no back pressure?
The Razor's Edge
im guessing but something with the o2 sensor...i might be really wrong so flame away
98 Cobra
yea i was thinkin that too, that becuase the sensors arent there that the computer is sending the car into a safe mode.
Off topic but what color is your car? Specific name if you got it.
all motor
92 coupe
9.94@136.40
without o2 sensorsthe stock ecu is setting a preprogrammed "tune" it is in open loopwithout feedback from the sensors
98 Cobra
i dont know specific color but its 2 tone silver, a darker silver on top with obviously lighter on the bottom
98 Cobra
if i just plug the sensors back in withought the pipes would it fix the no feedback? i mean the engine light will still come on but maybe it wont run lean
1990 LX hatch
How do you know it's running lean?
This is also the question i have.
98 Cobra
all motor
92 coupe
9.94@136.40
A wide band O2 or an autometer guage? the autometer gauge reading off of stock O2 sensors is next to meaningless.
I tried using mine to tune my nitrous once. It actually read leaner when I fattened up the fuel jets... BTW I ran my 88 without O2s for about 3 years with no ill effects other than having shitty fuel economy and it running rich below 2000 rpms. The O2 sensors don't really have much effect above 2500 rpms
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
98 Cobra
its a autometer guage but i dont know if it runs off the o2 sensors and i put th pipes back on and the guage reads fine
1987 Mustang GT
i wouldn't trust that gauge
98 Cobra
should i re rout it or something?
Ditch that gauge, and get a good wideband o2 meter. This is ofcourse, if you can afford it. With the gauge you have now.. if your running on the lean side of stoich, the gauge will tell you your lean.. even though you may only be lean by .02:1 With the o2 sensors disconneted, the car will actually run slighty rich. With the exhaust being disconnected, that doesnt effect the A/F ratios, unless you take the o2s off.
Well, if you didn't have any O2 sensor...think about this...how did the guage now you were running lean??
lol...no O2s means no sensor sending unit.
98 Cobra
true, but still is the whole guage inacurate or just how it was installed?
The gauge just isnt accurate.
Threads Similar to: running lean
| Running Lean | ROUSHME661 | V6 Mustangs | 22 | November 30th, 2007 01:47 PM |
| RUNNING LEAN !!!! | 97MUSCLESTANG | Modular Mustangs | 6 | March 5th, 2007 09:03 AM |
| My Car Is Running Too Lean, How Do I Fix It? | SPEEDRACERCHICK02'92' | 99-04 | 10 | December 13th, 2006 11:54 PM |
| 96 GT Running Lean on both Banks | kennyvick | General Tech | 4 | September 28th, 2006 10:31 PM |
| 1995 5.0 Running Lean | jcc1991 | 5.0 Mustangs | 3 | September 7th, 2006 10:58 AM |
