Discussing Roller rockers for victor jrs? in the 5.0 Mustangs Forum. Which roller rockers should i be looking for? They will be used on a set ...
Old January 21st, 2008, 03:29 AM   #1
Which roller rockers should i be looking for? They will be used on a set up victor jrs that are are going on a 408w. Im going for a custom roller cam thats going to be good for both street and strip
Old January 21st, 2008, 06:14 AM   #2
On Probation
Tony_90fox's Avatar
Talk to whoever is grinding your cam. The lift of the cam will determine which rockers you will want.
As for brands of rockers, there are alot... Harland sharp ,jessel, crane, FMS, comp cams, and scorpion.
Go ahead and put some good springs on the heads if not done already
MM Sapper Squad
Originally Posted by Regency 2007 View Post
MSO's stupidity has never stopped amazing me since the day he joined this forum.
Old January 21st, 2008, 08:59 AM   #3
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
Like tony said, you need to talk to your machinist to get the exact specs of the rockers you want. The RPM's your gonna turn affects the choice too. But as for brands if you have the money to burn buy crane. They are usually around $400. I bought Comp Pro-magnums for my windsor.
something like this if you want crane: http://store.summitracing.com/partdetail.asp?part=CRN%2D36757%2D16&autoview=sku
and here are the pro-magnums: COMP Cams Pro Magnum Roller Rocker Arms: CCA-1332-16 - summitracing.com
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old January 21st, 2008, 09:23 AM   #4
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Crane Gold rockers will handle anything you throw at them. They are the only rocker arm I use. There are other good brands out there as well but I've never had a problem with the Crane Golds. Shaft rockers are nice too if you can swing the extra cash.
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Originally Posted by Srt2stang725 View Post
I had one.....it was the most badass car ive ever owned...I sold it because it was too fast
Threads Similar to: Roller rockers for victor jrs?
roller rockers terribleonexx88 5.0 Mustangs 10 January 21st, 2008 12:14 AM
roller rockers? superman5.0 5.0 Mustangs 7 July 27th, 2007 12:51 AM
Roller rockers? aj28 V6 Mustangs 7 July 15th, 2007 09:17 PM
new roller rockers 03stanger 5.0 Mustangs 51 March 19th, 2007 11:50 PM
Pro Comp roller rockers Bossman351 Parts 5 August 31st, 2005 11:02 AM
