Can't get my new engine running correctly
Old January 21st, 2008, 06:23 PM   #1
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
My cay just won't run correctly, the idle surges, throttle response is terrible, then it wouldn't start and I pulled plugs and they were wet with gas and bought new ones and it cranked again. With all the new and modified parts and peices do you think I need to get a chip burned for the mean time untill I can get a piggy back system? I built a 306 with the following parts: I have TFS trackheat upper and lower intake, BBK 70mm throttle body and egr spacer, 24# injectors, stock fuel rail, Accufab AFPR, 80mm MAF calibrated for 24's, TFS heads 58cc ported and polished, 1.6 TFS roller rockers and pushrods, TFS roller lifters, Anderson HiRev valve springs, TFS stage 2 cam, TFS double roller timing set, DSS Pro pistons -13cc, stock rods and crank, BBK L/T headers with BBK O/R H pipe and BBK underdrive pullies. I have removed the A/C and the charcoal canister. I have also moved the P/S to A/C location. Any help or suggestions are welcome!
Old January 21st, 2008, 07:31 PM   #2
e3sean's Avatar
1988 lx
9.68@142
maybe vaccume??
<font size=4><b>MILITARY CREW
Old January 21st, 2008, 09:04 PM   #3
shurb125's Avatar
Originally Posted by e3sean View Post
maybe vaccume??
Checked all vaccum lines all is good, I just beleive that there is more to it than that, it seems no matter what you try it still dosen't run right.
Old January 21st, 2008, 09:05 PM   #4
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
what year is the engine? do you have speed density or maf?
Old January 21st, 2008, 09:38 PM   #5
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
try clocking your maf
Old January 21st, 2008, 09:47 PM   #6
Holy Dick Castle!
dr.gonzo!'s Avatar
now I see maf lol. there still could be a vaccume leak in the gaskets on your intake.
Old January 21st, 2008, 10:17 PM   #7
shurb125's Avatar
what exactly do you mean by clocking the maf? rotating it say 90*?
Old January 21st, 2008, 11:10 PM   #8
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
shurb- thats correct, 90* more or less, see if that helps.
Old March 1st, 2008, 09:07 AM   #9
flamestang's Avatar
flamestang is on a distinguished road
sounds like timming way out.
Old March 1st, 2008, 09:56 AM   #10
e3sean's Avatar
1988 lx
9.68@142
did u get it figured out? u can check and see if u have a leak spray some carb cleaner around the intake gaskets if the motor reacts in any way u have a leak..
Old March 1st, 2008, 10:06 AM   #11
ujslost's Avatar
Sounds like timing is way out or some plug wires are crossed.
I just ran into this same problem on my carbed engine. fucker would crank and pop thru the exhaust and the carb. It turned out my #3 and #7 wires were crossed. Found out after replacing dist, plugs, wires, intake gaskets. Always go back and check what you did, and double check the basic things like firing order. PPL get so comfortable with these areas they easily overlook the little things like I did.
Old March 1st, 2008, 12:52 PM   #12
shurb125's Avatar
Come to find out I had the wrong MAF on the car, I bought one off ebay for 87-93 and it turned out to be one for a 94-95. Changed it to a C&L and problem solved
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer
Old March 2nd, 2008, 01:47 AM   #13
teal89's Avatar
89 Mustang Lx
teal89 is on a distinguished road
Now sue the hell out of those Ebay guys who tried to pull a fast one on ya. Or go to them and do a burnout all the way around there shop
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot
Old March 2nd, 2008, 02:04 AM   #14
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
yea, sue the hell at of them for the 100 bux that part is worth......
or just ask for a refund
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old March 2nd, 2008, 02:55 AM   #15
teal89's Avatar
89 Mustang Lx
... Ask for a refund LOL Better yet... DEMAND A REFUND! Yeah. Or you could be nice. I don't like it when people try to fuck people over. Wish they would do it right and be done.
Threads Similar to: Can't get my new engine running correctly
what can cause a rich running engine? kreil45 5.0 Mustangs 2 March 30th, 2007 02:22 PM
Continuing saga of a rough running engine mickchu V6 Mustangs 3 January 28th, 2007 08:53 PM
rough running engine mickchu V6 Mustangs 9 January 24th, 2007 11:28 PM
Tranny Not Shifting Correctly 94mustanggt 94-95 9 September 22nd, 2006 07:28 PM
Anyone here running a stand alone engine mgt system? IcantDo55 The Clubhouse 8 August 24th, 2005 10:26 AM
