replacing fuel sending unit
LinkBack (1) Thread Tools
Old January 21st, 2008, 06:34 PM   1 links from elsewhere to this Post. Click to view. #1
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
How would I go about replacing the fuel sending unit? I have an 88 mustang conv. can I access the part by pulling the pump or do I have to drop the whole damn tank? any pics or tech advise is great. just please dont tell me I have to drop the tank. Its way too cold to go through all that. its a convertible so it may not be the same as a hatch.
and why the hell cant I copy and paste in the fourms P.I.N.A!
Old January 21st, 2008, 06:50 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You have to drop the tank to get at the pump and the sending unit. Its not a big deal to drop the tank. Run the fuel level low. There are two straps that hold the tank on. One bolt each. Then there is the fill tube and fuel lines. The fuel pump assembly is on the passenger side of the tank. The sending unit is in the middle. From start to finish it might take you 2 hours.
Old January 21st, 2008, 07:09 PM   #3
ryans88gt's Avatar
yeah, run it empty before you do it. Dropping a full tank sucks, each gallon of fuel weighs about 6 lbs.
Old January 21st, 2008, 08:43 PM   #4
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
make sure u don't push the round rubber gasket into the tank that seals the fuel neck when you reinstall the tank. I hope im not the only one that has done that.. lol
Old January 21st, 2008, 08:55 PM   #5
1992 LX 5.0
Devine is on a distinguished road
+1, it's kind of akward getting it back in even when it's close to empty and has a jack under it. don't try it full
Old January 21st, 2008, 09:02 PM   #6
Holy Dick Castle!
dr.gonzo!'s Avatar
That sucks. I dont have a garage to work in and the ground is cold as nancy grace's va-jay-jay I will get to it in 2 months I guess, the car that is.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/51866-replacing-fuel-sending-unit.html
replacing fuel sending unit This thread Refback May 16th, 2011 10:51 PM
Threads Similar to: replacing fuel sending unit
Oil Sending Unit? silver99gt 99-04 3 January 10th, 2008 12:44 AM
water temp sending unit Superfly76 99-04 23 April 30th, 2007 12:01 PM
Fuel Sending Unit terribleonexx88 5.0 Mustangs 6 November 1st, 2006 10:29 PM
Installing Oil Sending Unit For 96 Mustang GT gtdan 96-98 4 September 6th, 2006 06:40 PM
installing oil sending unit for 96 mustang gt gtdan 96-98 0 September 6th, 2006 04:28 PM
