Discussing explorer intake in the 5.0 Mustangs Forum. i got one 2day at the junkyard for 60 bucks and i wanna know if ...
Old January 21st, 2008, 06:40 PM   #1
terribleonexx88's Avatar
explorer intake
i got one 2day at the junkyard for 60 bucks and i wanna know if i need to do anything to is b4 i put it on my car(90 lx). the sticker on it said 12/20/96.
92 notch project ..new plans.. 2.3l turbo anyone with 2.3 block or complete motor lyin around pm pleaseeeeee(someone in the new england area)
Old January 21st, 2008, 06:57 PM   #2
what gaskets should i use i have the stock e7 heads.
Old January 21st, 2008, 07:00 PM   #3
ryans88gt's Avatar
Is the intake runner drilled and tapped for the ACT sensor?
I'd also clean it up. What does the PCV oil baffle look like under the lower. You might want to install the larger baffle if it is not already on there.
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old January 21st, 2008, 07:41 PM   #4
no i need to drill and tap that, the boss is there tho, also it has the big baffle in it.
Old January 21st, 2008, 07:58 PM   #5
Tony_90fox's Avatar
Definitely not pretty but you will notice a little bit.
Suck on it Trebek. Suck it long, suck it hard.
Old January 28th, 2008, 08:59 PM   #6
wat size drill bit and tap do i need for the act
Old January 28th, 2008, 10:54 PM   #7
tmoss's Avatar
19/32" bit (9/16" bit will do) and a 3/8" NPT tap. You got an internal EGR intake, so just clean it up and use the stock EGR spacer.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer P heads drilled for smog, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ
www.tmossporting.com
Old January 28th, 2008, 11:26 PM   #8
thanks dude, anything special with the vaccum lines theres a bunch of extra.
Old January 28th, 2008, 11:42 PM   #9
ryans88gt's Avatar
One small one goes to the EGR, the other small one goes to the Fuel pressure regulator. Then you need one 3/8" to go to the PCV valve and the other 3/8" to go to the vacuum tree. The rest you can plug off.
Bead blast and clear coat that bitch.
88 GT 11.4 @ 118
Old January 29th, 2008, 12:02 AM   #10
i was thinking black high temp because i dnt have a bead blaster.
Old January 29th, 2008, 01:09 AM   #11
ryans88gt's Avatar
Take it to a body shop, they should be able to media blast it cheap.
88 GT 11.4 @ 118
Threads Similar to: explorer intake
For Sale Explorer V8 Intake HTK241 For Sale 0 December 9th, 2007 01:21 PM
explorer intake notsoslow50 5.0 Mustangs 8 August 23rd, 2007 09:41 PM
explorer intake patwrecked 5.0 Mustangs 1 July 18th, 2007 06:52 AM
Explorer Intake 95blackbeauty 94-95 5 April 16th, 2007 10:20 PM
Explorer Intake hmotes 5.0 Mustangs 22 March 4th, 2007 03:47 AM
