1992 LX 5.0
Clean Injectors?
Just picked up some 24# injectors out of a 95 lincoln continental. At least I think they're 24
![]() Any recommended cleaning/service to do prior to attempting to use them? Got a 24# c&l tube on the way. Trying to decide on putting the new injectors in prior to heading back to the dyno, or wait til afterwards and see how the stockers hold up. Just installed our trick flow intake/cam/heads over the weekend. Thanks again to Ujslost. He helped us get everything in, on top of going on a high speed run to Seco 30 minutes before closing
i think i remember reading somewhere that cleaning them consists of blowing alot of air through them.
As far as changing them before or after the tune, i would do it before...Whoever is tuning the car will be able to lean the car out if it is running rich because of the injectors.
98 Cobra
ive heard that soaking them in cleaner works good
1992 LX 5.0
2003 Ford Mustang Cobra
9.94@140.25
The correct way is to have them cleaned and flowed. We have a cleaning and flow bench availible if your interested.
JPC RACING : Home of The Quickest & Fastest 3v on The Planet! '07 & '08 NMRA FACTORY STOCK CHAMP 2007 NMRA ROOKIE OF THE YEAR Quickest Pass In Factory Stock History 11.072 : Best MPH 121.01 : E7's |
1989 5.0 fox
11.6
y dnt u jst buy new ones n-stead of getting them from an old car?
1989 5.0 fox
11.6
but then again ive also heard soaking them works good.
1990 LX hatch
When you test them, do you have a large assortment of injectors to get a good average?
1992 LX 5.0
these are just interim injectors until we get bigger ones. Just put a new top end on and knew the 19lbs would be stretched to their limits, but didn't want to drop $300 on a set of 24lb injectors when I'm going to put a supercharger on in a month or two and the 24lbers would be obsolete.
9.94@140.25
Our guy has an ASNU Injector Flow and Clean Bench You do all 8 at once. Check flow and pattern first then try to clean. Some still won't clean and if so you need to replace. Also just because their new doesn't mean anything. I had my new 60's flow and one was trash.
1992 LX 5.0
Found this link: Ford Fuel Injection » Fuel Injector Cleaning
Thinking about just replacing the o-rings/spacers/pintal caps/filters and trying the soaking thing. Anyone see how the above cleaning method would damage the injectors? |
Seem like it would be fine. the only think I would worry about is leaving them soak for too long in an agressive solvent might weaken some of the plastic.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#13 | |
9.94@140.25
you are so "pro-my clean and flow bench" O_O its like everything everyone says is against what you believe and is wrong. there are ways to clean things without sending them away and paying someone to do it :-)
This is mostly a DIY forum.. try to help answer the question of how he can safely clean them without trying to earn some money?
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
1992 LX 5.0
dude just clean em. make sure you remove the o rings before you do it. if you think the solvent is too strong, add some gas to it :-)
1990 LX hatch
Do you flow to check them, or flow test to match?
#18 | |
Because everyone does not have 300 buck to spend. If you can get them on the cheap then go 4 it.
#20 | |
1992 LX 5.0
The stock tubing wouldn't work for the 75mm TB, so we've got the true flow elbow with it as well. When we go to a charger, we're planning on ebaying the MAF w/ the elbow. So far we've had 0 problems with it, pretty pleased with it actually. |
Threads Similar to: Clean Injectors?
| clean | HMUSN | The Clubhouse | 13 | January 1st, 2008 03:59 PM |
| The Right 5.0 to BUY!!! Clean | Texmjs | 5.0 Mustangs | 6 | July 26th, 2007 11:25 AM |
| best way to clean rubber off? | adam0421 | 2005 - 2010 | 7 | April 17th, 2007 09:29 AM |
